I seriously need help.......my car keeps on overheating PLEASE DONT REMOVE!!!!
Old May 18, 2004 | 06:53 PM
86305Z28's Avatar
okay let me make some things clear......this is what i have
86 Camaro Z28, 305 v8 5.0 TPI
NEW 3 Core Radiator
NEW 16pds Radiator Cap - Pressure Release
NEW Water Pump
NEW Thermostat (185 or 195)
Bypassed the Heater Core
Flushed the whole system with that Prestone Flush Out Kit
Checked Oil
Dumped some of this Car Cooler i saw on 2 Guy Car Garage
I think its called the Aim Dam........thats fine.......
sooooo after all this IT'S STILL OVERHEATING!!!!! Bubblin in the overflow BIG TIME......not some lil bubble bubble its a rumble....anti-freeze comin out tha cap......
What me and a few other people were thinking was that their possibly is a block in the engine......maybe there was corrosion in there n it fell over and its blocking the passage.....
My question is is there a way to pressurize the motor to get a good strong stream of water thru the motor in order to possibly get whatever the blockage in the motor is out of it??
I need help desperately, if someone can tell me how to get the blockage out that would be absolutely great.....its my only car and ive been smoochin rides offa people in fear that ima blow the engine..... <--------says it all
Old May 18, 2004 | 08:49 PM
idunno's Avatar
you sure theres no cracks in either the heads or block? they would cause the bubbling
Old May 18, 2004 | 10:18 PM
Lonnie Pavtis's Avatar
How soon does it start bubbling? Is it within a minute of cold start-up or does it gradually get hot then start to bubble?
A bad head gasket will show the same results. Basically the leaking combustion pressure will displace the water in the engine & cause the engine to get hot. Some air will bubble out the radiator as well.
Old May 18, 2004 | 11:05 PM
96speed's Avatar
Any condensation in the exhaust? Some is normal, but there doesn't have to be white clouds of smoke to be a head gasket.
I'm betting its a had gasket...
Ryan
Old May 19, 2004 | 11:32 AM
86305Z28's Avatar
well i can drive on the highway and the temp will never go above 220......but once i start gettin into town traffic then thats when the temp goes up....way up....itll start bubblin over prolly round 15 mins or more or town driving....
Old May 19, 2004 | 11:59 AM
JucinGTA's Avatar
Sounds like your fans arent kicking on. Its getting enough cool air when you drive fast or at high speeds but when your in town, no air flow your overheating. Check your fans.
Old May 19, 2004 | 02:05 PM
What temperature is the coolant gauge indicating when the bubbling starts? Probably would have been a lot clearer if you had included all this info, regarding the actual temps, freeway driving vs. in-traffic driving right from the start.........
Old May 19, 2004 | 05:52 PM
The stock fan setting is also around 210-220 on a 3rd gen.. When does your fan come on? Your car should never go above 220.
Also when you replaced the waterpump was it reverse rotation. The serpentine belt cars used a reverse rotation pump & the v-belt cars were standard rotation. I have seen this too many times where the pump goes bad & the local autoparts reject sells you the wrong year pump.
Old May 19, 2004 | 08:11 PM
RCF925's Avatar
One other thing is if your thermostat is in backwards it will have those symptoms.
Old May 19, 2004 | 09:42 PM
OneFlyn95z28's Avatar
cracked headorblowhead gasket.
everytime my 3rd gen over heated it was because I had the Air dam off for snow It would flat boil over on the freeway at 70mph
Old May 20, 2004 | 11:40 AM
JucinGTA's Avatar
You should not remove that airdam that is needed for proper cooling on the car.
97SSdude
Dec 31, 2014 07:43 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
USAirman93
Nov 24, 2014 03:37 PM
