350 TPI combustion chambers
Old May 15, 2004 | 05:57 PM
TinkerToy's Avatar
Cool 350 TPI combustion chambers
I Equalized combustion chambers on stock heads after pocket port and came up with 65.2 cc on each chamber, which is about 8.7 compression ratio.
If I mill the heads .020 I will have a compression ratio of about 9.05.
If I go .030 on the heads, the compression ratio will be the actual advertised compression ratio of 9.3.
With the price of gas and non-availability of 92 octane (at times) should I go with a 9.05 compression ratio and avoid detonation problems with low octane fuel, or go with a 9.3 and let the knock sensor take care of this problem when I have to use low octane fuel.
This is my daily driver.
Old May 20, 2004 | 12:09 PM
formularpm's Avatar
Do you plan to keep the engine naturally aspirated? If so then go with 9.3:1. L98s (Fbody) came from the factory with similar figures and Ive never heard of anyone having to run premium to avoid knock. Keep the engine cool and be conserative on the ignition advance, and 9.3:1 should be no problem.
Nayr
Mar 3, 2023 08:34 PM
G-BODYT56
Jan 14, 2022 11:14 PM
HAWG
Sep 25, 2015 11:41 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
