I need fuel setup help for a big hp 383...
Old Feb 22, 2005 | 03:25 PM
texasTA's Avatar
Guys I have tried to talk to some vendors and scoured the boards and still havne't come up with the info I am looking for. here si what my setup will be:
fully forged 383
fully ported LT4 heads/intake by Jordon Musser
solid roller camshaft
58mm TB
direct port 300 NX shot
We are going to run a stand alone fuel cell for when the nitrous is in use. I am not getting the nitrous setup installed until June, but right now I am putting the motor together.
So what type of fuel pump, fuel injectors and any other associated fuel items are required. Is the Aeromotive setup something I should consider or can I get by on some Racetronix fuel injectors and fuel pump?
Also, what size injectors do you think I will be needing? The motor should make about 460-480rwhp without the hose.
Old Feb 22, 2005 | 05:47 PM
Racetronix's Avatar
Re: I need fuel setup help for a big hp 383...
fully forged 383
58mm TB
Racetronix in-tank system + 42# injectors would be just fine.
Old Feb 22, 2005 | 07:04 PM
texasTA's Avatar
Thanks Racetronix for the reply. When you say the intank system are you talking about that plug and play system of ya'lls? Thanks again.
Old Feb 22, 2005 | 07:22 PM
Racetronix's Avatar
Correct.
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
