how much compression
Old Mar 16, 2006 | 06:12 PM
  #16
SStrokerAce's Avatar
Re: how much compression
If you are getting knock at high RPM, you put too much compression in it. I've used aftermarket systems on the dyno to verify knock. Usually it's only at low RPM in well done setups around 100-110% VE max. Once you crank heat into the cooling system and intake air temps the knock will definately increase.
Bret
Old Mar 16, 2006 | 06:34 PM
  #17
irocalot's Avatar
what is the effect of gapless rings into this equation? it would seem if you are on the ragged edge of detonation, it might not be a good thing to increase the sealing ability of the engine, correct?
Old Mar 16, 2006 | 09:02 PM
  #18
96speed's Avatar
Originally Posted by LiENUS
Chances are your cam software is looking at what duration would be best and using a icl of 110 to achieve that if you really want to drop it down find a cam profile with a different icl with similar duration or better yet, rather than using software, talk to a cam designer before trying to use the software.
Someone is helping with this as we speak. I was just trying to get a better idea.
Interesting thoughts in this thread.
Ryan
Old Mar 16, 2006 | 09:06 PM
  #19
LiENUS's Avatar
Ryan
What software did you use to help you pick out the cam specs?
Old Mar 17, 2006 | 10:18 AM
  #20
96speed's Avatar
I have no idea. I've been using a DCR calculator I picked up off of this site to play with the DCR and independent variables.
Ryan
Old Mar 21, 2006 | 12:25 PM
  #21
WS6 TA's Avatar
Originally Posted by IHI
Probably why the stock bottom end lasted soo long Oh well, next one will be a little "wilder". I gave up on mathmatics in racing (at our measily bracket level anyways) since after having a motor professionally built for the truck and told this wont work and that wont work, slide rule this and slide rule that.
Everyone has a tendency to mention that with equations and computer sims there’s a case of garbage in/garbage out, but no one seems to think about that just as important is what is done with/how the output is interpreted.
Old Mar 21, 2006 | 02:48 PM
  #22
IHI's Avatar
IHI
I know there are truely gifted folks out there that can acutally sim something on paper/computer and have the real product turn out exactly like they predicted, but these types are few and far between and/or really expsensive to obtain this great information from. I dont have a racing budget to afford these types so I just try to make educated guesses myself. Sure I'm leaving alot on the table but it's affordable and dependable which is what bracket racing is supposed to be, if I wanted max output obviously choices would be alot different.
The truck we had built was done using all these equations and slide rules and to put it lightly, the truck is about as mismatched and slow as can be for what it should be IMO. Things they said in the dyno room were debunked on the track. Things I've read about over the years seem to be more ice cream cruiser related and the track has proven these things worng as well.
Totally agree garbage in garbage out, 2+2 does'nt equal 3 or 5 on any calculator I've ever used either LOL
Old Mar 23, 2006 | 12:33 PM
  #23
marshall93z's Avatar
Does anyone know the DCR of the stock motors in LT1's? I don't think I've ever seen the complete cam specs anywhere?
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
