Head studs ???
Old Dec 30, 2002 | 12:56 AM
  #16
TAYLORMADE's Avatar
Studs will distort the cylinder walls differently then blots. So if you're block was honed with bolts and a torque plate I'd use bolts.
Old Dec 30, 2002 | 04:29 PM
  #17
Camaro_SS/R's Avatar
I just recently pulled my AFR heads with the newer head studs that can been pull off with the allen wrench. Not a big deal at all. So don't worry, very simple to pull the heads without pulling the motor. One long Saturday basically. This is not true for the older stud that can't be pull off with the allen wrench.
Talked to Nick, he was a great help. Get the ARP thread sealant not the lubricant. Put sealant on the bottom threads, both side of the washer, and on the top threads. Without a good sealant you will be leaking coolant into your block since there is a coolant jacket below some of the studs. Also don't over torque the studs, you may strip the block and have to call Nick on a Saturday, screaming for help!
cheers
Old Dec 30, 2002 | 05:06 PM
  #18
89ProchargedROC's Avatar
My machinist told me to use silicone and some sealer in the coolant system
Old Dec 30, 2002 | 07:57 PM
  #19
JordonMusser's Avatar
West South Central Moderator / Special Guest
yea, I use ARP thread sealant on the bottom of the studs, and ARP assembly lube on the nuts/washers.
Old Dec 31, 2002 | 04:29 AM
  #20
bowtiepwr's Avatar
>cool ... I got the ARP sealant and assembly lube when I first got my cylinder heads .
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
May 27, 2015 09:53 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
