Gold Coating from Swain and water injection
Old Jun 10, 2004 | 07:52 AM
Highlander's Avatar
I've heard that the gold coating from swaintech is very hydroscopic and that is why you have to avoid prolongued atmospheric exposure before installing it on the engine, since the coating may later on come off.
Will spraying water or alcohol have any i'll effects?
I know richard is doing alcohol injection but not sure if it should be avoided or recommended.
Old Jun 10, 2004 | 08:02 AM
Mindgame's Avatar
Sounds like a good question for Dan Swain.
The piston crown isn't going to see prolonged exposure anyways. A small bit of water vapor then poof, it's gone.
-Mindgame
Old Jun 10, 2004 | 08:03 AM
Highlander's Avatar
probably... but i was still wondering... I guess I will call them as they have my pistons now for GC and PC-9.
Old Jun 10, 2004 | 08:18 AM
rskrause's Avatar
Moderator
I use their regular TBC and not the gold. On teardown, the regular stuff is always still there but the gold seems to have taken a vacation.
Rich
Old Jun 10, 2004 | 08:30 AM
Highlander's Avatar
So you do NOT recommend the gold coating???
and what do you recommend for the sides?
Old Jun 10, 2004 | 08:37 AM
rskrause's Avatar
Moderator
Swains "regular" Thermal Barrier Coating for the crowns. I have not used the skirt coating.
Rich
Old Jun 10, 2004 | 08:38 AM
Highlander's Avatar
Im calling mega fast...
I told them to do the Gold coating...
I did a set of GC for a mazda F2T engine and they looked nice...
but i don't like your comment about the gold coating taking a vacation... jeje
Old Jun 10, 2004 | 08:55 AM
Highlander's Avatar
Well.. did the change...
Dan told me that the GC was a bit better, specially for turbocharged engines... He also adviced me NOT to go with the GC due to the extreme humidity as the coating needs the engine heat to do the final curing...
He also told me that if it where a turbo engine he'd recommend it more than for a S/C... i was like :WTF:
Probably a Turbo car sees higher EGTs...
Old Jun 10, 2004 | 10:59 AM
mongse_1's Avatar
A lot higher. The headers I had coated for the IROC started to bubble last week when we were road racing it. I thought the coating was coming off, but I was assured it's normal and it's the last stage of curing. The only way to prevent this would've been to expose the entire header to extreme temps before installing them. Next time, I'll throw them in a volcano.
Bobczar
Oct 23, 2015 11:22 AM
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
