Fuel sender malfunction??
Old Mar 3, 2003 | 11:50 PM
90rocz's Avatar
I haven't ran across this before. Just got an S10 Blazer, cheap and the fuel gage buries past full. I checked the continuity of the wiring, it's good. I checked the voltage at the gas tank and get about 8.5volts@pink wire with KOEO. Normal??
It has 3-wires into the tank: pink=sender to dash, black=chassis ground near tank, tan=fuel pump to fuel pump relay. The harness was butchered @ the tank, so I got the correct wires and reconnected it as it was supposed to be.(?)
What makes the gas hand move; voltage dropped across the variable resistor(sender), or varying the percertage of ground by the sender?
Vehicle runs great!, but I must know how much fuel I have left in there.
Old Mar 5, 2003 | 10:20 AM
This really doesn't belong here.
Locking
HectorM52
Jul 30, 2017 11:46 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Jul 4, 2005 05:00 PM
tbyrne
Jul 2, 2002 05:37 PM
