flywheel ????'s
Old Mar 1, 2003 | 03:48 PM
Deadcarny's Avatar
flywheel ????'s
i posted this in the LT1 tech, but i figure i may get the response here. i just aquired me a 383 LT1 for the Z. it was in an auto car, and mine is a manual. the 383 has a 2 piece main seal and my flywheel will not work with the crank. anybody know where i can get a flywheel for this?
Old Mar 1, 2003 | 04:37 PM
Teknohund's Avatar
You will need to get a flywheel from Centerforce. Part # 700100 if i remember correctly. Just go to their website, and match up the #'s with the LT1 flywheel to the one for the pre-1986 engine flywheels. It should be right around 300 bucks
Hope that helps
Chris
Old Mar 1, 2003 | 10:51 PM
Deadcarny's Avatar
thanks. i think it might be 700110. i will call around about it. thanks.
Old Mar 2, 2003 | 10:41 AM
SStrokerAce's Avatar
why is it a 2 peice rear main seal LT1? Seems kind of odd? what's the casting number on the block?
Old Mar 2, 2003 | 10:52 AM
Deadcarny's Avatar
because it is a 2 piece stroker kit. the block is a correct LT1 block with the 327 cast and the lt1 front cover. it is in my friend's shop right now so i do not have the numbers.
Old Mar 5, 2003 | 03:37 PM
Deadcarny's Avatar
the right part number was 700107 for the centerforce flywheel for an internally balanced 2 piece rear main and an lt1 clutch. summit had it in stock for around $350...
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
