Expected valve train life at higher RPM's
Old Nov 2, 2007 | 08:57 PM
  #31
95ttoplt1's Avatar
Originally Posted by airflowdevelop
Been there...done that ...got the Tee shirt. You don't need it for your power level though. Keep your eye on the goal!
Will do! Thanks for the help. Sorry we didn't get connected when I was looking for a head porter, maybe on the next one
Old Nov 2, 2007 | 09:49 PM
  #32
rskrause's Avatar
Moderator
Do you mean BTDT regarding a 412ci LT1 or 700hp from a pump gas 23 degree head 370ci motor? That is impressive, if it's the latter.
Rich
Old Nov 2, 2007 | 10:01 PM
  #33
airflowdevelop's Avatar
well...I was refering to the first...but the second is also true.
421 LT1, and atleast 1 700FWHP 93 octane SBC's
Old Nov 2, 2007 | 10:02 PM
  #34
1racerdude's Avatar
368 sb-2 800hp smallblock
368 bowtie block sb-2 heads jessel ,belt driven oil pump system,evacuation system, H&F PERFORMANCE BUILT have all dyno records 10 passes on motor 920,s in 29,000lb 69 camaro through mufflers. $9,500.00
353 DART BUICK HEAD- SMALL BLOCK CHEV
Fresh,750 hp,dyno sheets included.
Includes ceramic coated dragster headers.Ran 7.31 @180 mph in 1500 lb dragster.
Above Added: Fri October 26, 2007, 3:28 pm EST
Bronze lifter bushed,splayed steel cap bowtie block,Cola crank,JE pistons,Manley
70 series aluminum rods,Comp cam,Crower lifters,Jesel belt & rockers,Dart buick
heads with titanium valves,Dry sump,sheet metal intake,front drive distributor,Ati
aluminum damper.Fresh,750 hp,dyno sheets included.$8500.00 obo
Old Nov 2, 2007 | 10:13 PM
  #35
95ttoplt1's Avatar
Pump gas??
EDIT:
Daddy spot's a nitrous plate as well, I like, now make it run on pump gas and we have a winner
The High mount Opti
Old Nov 2, 2007 | 10:14 PM
  #36
95ttoplt1's Avatar
Might I ask what the pump 700hp 93 octane motor consisted of??
  #37
1racerdude's Avatar
Originally Posted by 95ttoplt1
Pump gas??
Could be!!!!!!!!
There are some doing it.Check out the 750HP version.
Old Nov 2, 2007 | 10:18 PM
  #38
Not unless you are willing to write the check to buy one.
If I gave all the secrets away, I would be eating Ramen instead of steak.
Old Nov 2, 2007 | 10:22 PM
  #39
1racerdude's Avatar
BIG cam, SB2.2 heads and intake, and 13.5-14.5 static compression.
Want One for 'bout 35,000 used?
Old Nov 2, 2007 | 10:23 PM
  #40
1racerdude's Avatar
I'll say.
Steak??????????
Old Nov 2, 2007 | 10:26 PM
  #41
1racerdude's Avatar
Pump gas??
EDIT:
The High mount Opti
ALL MOTOR.
Old Nov 2, 2007 | 10:30 PM
  #42
mdacton's Avatar
a small cid making that kind of power.......$25,000?
I could do a nice big block with that kind of money...and blow the doors off of 700 h.p.
Old Nov 2, 2007 | 10:40 PM
  #43
1racerdude's Avatar
323ci splayed value 840hp,358ci splayed value 940hp
Not on PUMP GAS
Old Nov 2, 2007 | 10:43 PM
  #44
1racerdude's Avatar
Can always take the SB to 460 and a butt load of hose. That would make it even,ya think.
323ci splayed valve 840hp,358ci splayed valve 940hp.
323ci splayed value 840hp,358ci splayed value 940hp, complete intake to oil pan, flywheel to dry sump. with out carbs, asking (323) 16,000, (358) 20,000
Put 3/400HP of hose on this and ya will go fast enough.
Old Nov 2, 2007 | 10:47 PM
  #45
95ttoplt1's Avatar
Here I sit eating Ramen..........
