Is Evans NPG+ better than 100% water?
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Re: Is Evans NPG+ better than 100% water?
Originally Posted by 4drLT4
Taner,
When talking with Evans, they recommended running without the stat in order to ensure a continuous flow system....which of course requires a radiator capable of such flow. I actually found that i ran too cool when trying it without the thermostat, and went back to a 160* as a compromise. Your mileage may vary.
As far as the cap goes, it is a pressureless system, so NO cap is actually needed. The reason for the zero pressure cap, as Evans puts it, is to avoid inhaling the fumes from the NPG+, which can get irritating at times....based on my experiences. The stuff actually smells alot like pancake syrup if you ask me.
Anyway...because the Impala has its cap on the overflow tank as opposed to the radiator, and no zero pressure cap is available for it, I simply ran my stocker without problems. I suppose you could take the stock cap and remove the spring pressure mechanism and arrive at the same goal.
what if i drilled a small hole into the thermostat to promote flow, thus reducing the pressure in the system? all i have ever run is standard 50/50 water/coolant mix. i am sure it isn't rocket science, but i am all ears to the folks that have done this with success.
also won't it take a long time to heat the motor up? i am not too concerned with gas mileage, lmao!!! but still want to be able to heat the motor up within a few minutes at the track if the motor is cold.
tia!
tia!
I ran NPG+ in my previous Impala for over a year. It sure did allow me to run any amount of timing I wanted, and on crap 91 octane California gas. I found that my gauge showed what was going on in the combustion chamber....i.e, at a stop, or stuck in traffic, the guage showed cold, whereas when pushing it hard, the gauge would show hot.
I don't understand the hot/cold gauge comparo.
Originally Posted by arnie
Wouldn't thermally insulating the combustion chamber, be the opposite to using the NPG? IOW, By utilizing as much of the heat of combustion to push against piston crown, and consequently generate more torque, in lieu of heat going into the radiator, more conservative timing would need to be implemented. Whereas, by absorbing more of the heat of combustion into cooling medium, more timing could be utilized. Sorta like comparing aluminum head CR, to that of CR possible with same gas/timing, using steel heads.
One of the benefits that NPG allows is that you can run the motor warmer. A warmer motor gives you the same benefits of coating the chambers by making the motor more thermally efficient. If you could run the motor at 400 degs (if it would live which is not going to happen) then you would have even better thermal efficiency. That along with the ability to resist detonation is the key to this stuff really.
Bret
guys, I still don't see it. It's not passing my simple logic little brain.
I know just a little about heat transfer and fluid flow but certainly didn't write the book on it.
I still can't see how the NPG can thermally insulate the combustion chamber, and also removed heat from the cylinder head better, and allow for more resistance to detontion. I see that it is stated that this happens, but I just cannot see the sceince behind it. Remember, this is comparing NPG to 100% water and comparing it to regular 50/50 mix.
And I am open to having my mind changed, that is if I can ever "see the light".
Right now I'm of the school that believes water has the best heat transfer properties and with a good flowing water pump will by far out perform NPG in that department. When the water pump doesn't flow the water fast enough is when the cylinder will make steam pockets. But until that point, just how can NPG remove heat better than water? I don't see it?
And I don't see how a hotter combustion chamber can be less resistant to detonation? I do see how an insulated combustion chamber could make more power but that insulation has to be on the combustion side, not the water passege side. If the water passage is "insulated" from heat transfer, the combustion chamber is going to get HOT!!! and thus all the bad things that go with it.
Maybe people see advantages with NPG because the water pump just is not flowing well enough? Slow flow with 100% water will cause boiling - horrible performance. Slow flow with NPG will delay the boiling and provide less than horrible performance?
I'll leave it at that. I guess I'm playing devils advocate since I have not tried the NPG and am a follower of good ol water.
Anyone actually do drag racing testing? I guess engine dyno testing would be good info too. I've seen the NPG advertising but it only compares itself to 50/50 mix. It never compares itself to 100% water.
thanks, Karl Ellwein
Actually more water isin't better. At a point moving water too fast thru the motor will not allow the water to transfer the heat of the motor into the coolant. Faster isin't always better. (I think the limit is about 90 L/min or so but don't quote me on that.) Actually in most circle track racing they slow the pump down to reduce drag on the motor, and the new water pump designs do an even better job of this and cool the motor more effectively.
NPG doesn't insulate the chamber better, it does transfer heat better than water and resist Nucleate Boiling. That's what's causing detonation, isolated hot spots in the head, having one part of the chamber extremely hotter than another part will cause the detonation problems. Thermal Barrier coatings keep heat in the chamber, a higher temp coolant keeps the parts surrounding the chamber closer to to the temps in the combustion chamber so less heat is lost to the coolant, which improves thermal efficency.
I'm not here to change your mind or anyone elses. A 100% water mix is going to have the same problems that any water based coolant will have so the same things will happen. You should really read this site http://www.evanscooling.com/html/tech1.htm also David Vizzards book on short blocks (Pistons, Rods and Crankshafts) has a section in it about Evans NPG with dyno tests and that book was wrote in 1992.
Bret
Bret
Dang Dang Dang.
I re-read the Evans tech page and it still is comparing conventional coolant to the NPG. It does not compare 100% water.
I have to get that 1982 Vizard book and see what he says.
One thing that I was taught back in school is that higher water flow always results in more heat transfer away from a surface in a closed system. It is a LAW.
Check Stewart components web site tech area for more on this.LINK
Here is a snipet from Stweart components,
quote: 1 BTU is the amount of energy required to raise 1 pound of water 1°F. Of all common liquids water requires the most energy to accomplish this. Therefore water has a specific heat of 1°. An Ethylene Glycol/water mix has a specific heat of .5, meaning it requires only .5 BTUs to raise the temperature of 1 pound Ethylene Glycol/water mix 1° F. Propylene Glycol has a specific heat of only .3.
On a typical engine with a coolant flow rate of 100 GPM and an energy loss through the cooling system of 189.5 HP, water would need to gain only 10° F, Ethylene Glycol/water mix would gain 20° F, and Propylene Glycol would gain 33.3° F.
This equation is complicated by the difference in a vapor point of the 3 coolants. Ethylene Glycol and Propylene Glycol have higher vapor points and thus can absorb heat at higher temperatures. However, even with it's lower vapor point, water still carries more heat per unit than the others. Unquote
Karl
Karl
Originally Posted by quickSS
Dang Dang Dang.
Still the problem you see with any H2O based setup is that it keeps the properties of H2O. Lower surface tension, lower boiling point that needs pressure to raise it to operable levels etc.... The big problem is the Nucleate Boiling, if you can get rid of that it will cure detonation. The problem with Nucleate Boiling is that it compounds it self rapidly and only looses the steam pockets once the motor is completely cooled off.
Karl
Karl
Karl, H2O might do better in taking heat out of the motor but that's not really the point. You don't gain a ton from that other than a colder motor which will radiate less heat into the intake tract and increase VE. If you can increase the the efficency of the rest of the motor (thermal, friction and fuel) and still isolate the intake tract from the added heat then you can gain VE too and be in a win win situation.
Bret
http://www.engineeringtoolbox.com/24_146.html
Karl's right. There is nothing in the thermo equations that take coolant velocity into account. The myth about the water flowing too fast came about through a cooling system design flaw, not through the physical properties of water. If the velocity of the coolant was an issue, it would affect the NPG equally. Pump speed is fixed - you can't change it. So whther or not you belive the velocity myth, it cancels out anyway.
IF you think of heat BTU's as physical objects, like rocks, you can imagine the coolant as a conveyor belt. BTU's are loaded on the conveyor belt in the engine, and unloaded at the radiator. A slow moving conveyor quickly gets loaded to capacity and cannot carry any more BTU's. Double the speed of the conveyor and you double the amount of BTU's you can carry.
Double the WIDTH of the conveyor, and you can carry twice as many BTU's at a given conveyor velocity. In this case, the width of the conveyor is analogous to the specific heat of the coolant. NPG has a specific heat of .3. Pure water has a specific heat of 1.0, which in our conveyor analogy makes it 3 times as wide as the NPG conveyor. This is significant because it means for a given pump speed it can move three times as much heat as the NPG.
The claim that NPG 'insulates' the combustion chamber, thereby increasing thermal efficiency, is pure smoke and mirrors. If you turn that statement around, it really means Evans is admitting that they cannot cool the combustion chamber as efficiently as pure water.
As far as nucleate boiling goes, Evans is putting more spin on that than a politician. Let's assume for a minute that the blurb on the Evans site is true. (You can't assume their statements are true, because they have a vested interest in selling their product and thus anything they say requires independent verification; but let's assume for argument's sake that their blurb is factual.) If you read Evans' own spin, they admit that NPG produces nucleate boiling just like water does. Their claim is that NPG produces smaller bubbles than water, not less bubbles. The smaller bubbles come about because of the lower surface tension of the NPG.
If that is true, and that's the best spin on the subject there is because that info came from Evans' site, then you can get the same effect with a couple of bottles of Water Wetter. Water Wetter achieves lower coolant temps by reducing the surface tension of water. Remember, lower surface tension is what makes NPG effective, according to Evans. Now you have the lower surface tension of NPG combined with the specific heat of water - thus you have a formula more effective than water alone and 3 times more efficient than NPG.
Thus, whether or not NPG is more effective than pure water is moot. By Evans' own logic, water combined with a surface tension reducer (Water Wetter) is superior to NPG.
From Stewart Components: A common misconception is that if coolant flows too quickly through the system, that it will not have time to cool properly. However the cooling system is a closed loop, so if you are keeping the coolant in the radiator longer to allow it to cool, you are also allowing it to stay in the engine longer, which increases coolant temperatures. Coolant in the engine will actually boil away from critical heat areas within the cooling system if not forced through the cooling system at a sufficiently high velocity. This situation is a common cause of so-called "hot spots", which can lead to failures.
Years ago, cars used low pressure radiator caps with upright-style radiators. At high RPM, the water pump pressure would overcome the radiator cap's rating and force coolant out, resulting in an overheated engine. Many enthusiasts mistakenly believed that these situations were caused because the coolant was flowing through the radiator so quickly, that it did not have time to cool. Using restrictors or slowing water pump speed prevented the coolant from being forced out, and allowed the engine to run cooler. However, cars built in the past thirty years have used cross flow radiators that position the radiator cap on the low pressure (suction) side of the system. This type of system does not subject the radiator cap to pressure from the water pump, so it benefits from maximizing coolant flow, not restricting it.
I see what you are saying Randy. And that matches all of what I learned in heat transfer and fluid flow.
As to the nucleate boiling, I think it was mentioned early in the thread that nucleate boiling is the state of the cooling liquid where maximum heat transfer is in effect. And I see that Evans is saying that. Nucleate boiling is what we desire and high flow takes best advantage of that. The point before nucleate boiling if fine too. But the point after nucleate boiling is where steam pockets are formed and heat transfer takes a dive. Used to call that "departure from nucleate boiling".
Just to clear that up.
But since I'm only seeing the points about how water is superior to NPG or NPG mix or EG or EG mix, I'm missing the points as to how NPG+ is better for producing power in an IC engine. Right now, to me it looks like NPG+ simply makes the cylinder head hotter and to me that would make it prone to detonation.
Randy, do you have that Vizard book?
Karl Ellwein
Karl Ellwein
Karl,
You're right again. Evans' claim about 'insulating' the cylinder head is just smoke and mirrors, like I said before. They try to claim that their coolant works like the high tech thermal coatings inside a cylinder head, but there's a fatal flaw in their logic.
Thermal coatings work to insulate the inside of the cylinder. NPG works from the outside. How does the fuel/air mix know what the coolant is? Why would it care? Too hot is too hot.
Thermal coatings work like a layer of indestructible styrofoam between the hot metal of the cylinder and the fuel/air mix. They prevent heat jumping from the metal to the fuel/air mix and causing pre-ignition. NPG, because it runs hotter than water, would actually INCREASE the heat transfer from the cylinder metal to the fuel/air mix, causing MORE detonation, not less. The analogy is pouring boiling water into identical metal cups, but one has a layer of styrofoam on the outside. Which cup are you going to pick up?
On the departure from nucleate bioling, when is that most likely to happen? Zooming down the drag strip? Flying around the road course? Hardly. More like when you're sitting in traffic with the engine idling (and thus the water pump barely turning) and no air flowing across the radiator (although electric fans go a long way towards dealing with that). So NPG might be good in a situation where you had a mechanical pump, mechanical fans, and did a lot if idling; but not in a performance situation.
