Different AFR LH/RH
Old May 13, 2007 | 03:48 PM
Viking's Avatar
Different AFR LH/RH
This is tearing me down....I need some useful hints!
I get diffent AFR between LH/RH cyl.banks under acceleration
- Swapped injector drivers
- Swapped side of the injectors
- Checked for vacuum leaks
- Checked for exhaust leaks
- Relocated both WBO2 bung at the same distance from cyl.head.
- Swapped side of the WBO2 units/sensorn
- Disconnected all the other inputs from TPS/MAP... to eliminate elec.fault.
- Grounded all the WBO2 eq at the same place
-> Still no change
Se picture from scan http://medlem.spray.se/gta324/mods/log.jpg
Could a vacuum leak between intake/head to the lifter valley cause this?
Why is it diffrent when I accelerate and not else?
Purple- RH AFR
Yellow- LH AFR
Red- MAP
Green- TPS
Black - RPM
Old May 14, 2007 | 04:28 PM
If I'm reading the chart correctly, you were running at about 2000rpm, and the the RH A/F was running about 15.5:1 and the LH was about 15.2:1. You opened the throttle (can't tell how much, the scale is cut off) and accelerated to about 2450rpm, then slowly continued to increase to about 2700rpm. During the gradual acceleration the RH A/F dipped briefly to about 13.5:1 and the LH to about 12.6:1, the the RH increase to 16.0:1 and the LH to 14.7:1.
The RH side is almost always a bit leaner than the LH side. When you are actually accelerating, the RH and LH A/F actually are the same (46.4-46.8 - appears the X-axis scale is seconds?)
What engine management sytem are you using? Is it a mass-flow or speed-density tune? Does it include a closed loop control system? Does the tune account for the boost, using a 1-bar MAP sensor, or are you running a 2-bar sensor? Is any other means used to add extra fuel under boost, like an FMU or a boost referenced fuel pressure regulator?
Old May 14, 2007 | 11:34 PM
Viking's Avatar
The dip is the AE, the scale is in seconds so its only a half second.
GM ECM, MAP, Open loop tune, 2bar code, this was done with no boost and around 80kPA and 50% TPS.
But I think I found something yesterday, burnt valves.............
Old May 15, 2007 | 01:38 AM
SABLT194's Avatar
Funny, I thought about this lat night and was going to recommend that you do a temp check on the primarys to see if you had a cylinder going south. That'll do it!
Steve
Old May 15, 2007 | 01:42 AM
Viking's Avatar
Did a temp check but didnt se anything at idle......
Anyway, searching for a EGT gauge on the net now to put in
Will remove the heads on thursday and see how bad it is.......
/N.
Old May 15, 2007 | 02:17 AM
SABLT194's Avatar
Could just pull the intake and headers off then do a leakdown an listen for the rushing air out the ports. However, when you get that far, yanking the heads is almost nothing. Don't ask me how I know
Steve
Old May 15, 2007 | 02:21 AM
Viking's Avatar
Pulled the headers yesterday (PITA) and put a hose down the intake runner and put AIR into the plug with pistan at TDC and felt air from the exhaust then went in and took a beer instead....so tired of this...........
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
FryedClutch
Sep 1, 2015 08:24 AM
bunker
Aug 21, 2015 10:21 AM
