Cam Bearings? PIC INSIDE
Old Dec 17, 2003 | 05:45 PM
TwEaKeDSS's Avatar
NO Help in LT1 Tech so ill try here...
What is the trick on installing them again? Where do the little dowel holes have to be lined up at? I thought you were alway's supposed to install the bearing's as follows.
FRONT bearing with the two holes lined up at 2 and 10 o'clock with the block facing upright standing in front of the block.
Then the rest of them the lil hole needs to be at the 3 o'clock position with the block facing upright standing in front as well..
BUT if you look at THIS you will see that they have the bearing in the 5 o'clock position if you had the block upright standing in front.. As you can see in the pic the block is upside down so it would appear that they are installing the bearing in the 11 o'clock position.. Isn't that wrong?
Old Dec 17, 2003 | 06:45 PM
Damon's Avatar
Assuming the LT-1 is still laid out basically like an older SBC in that area, I install mine different from either of the ways you described (coudn't tell anything from the picture- too grainy).
I install mine with the oil holes pointing straight down (6 o'clock) for all the rearward ones. The front one I have one hole at 2 o'clock and the other at 6 o'clock.
I have played around with putting the holes in different positions like at 4 o'clock on the rear bearings and 1 & 5 o'clock on the front. Worked just fine. Didn't help, didn't hurt.
There's quite a bit of flexibility since the oil annulus (groove) in the block around the cam bearing goes the whole way around the bearing. Oil will always get inside the bearing regardless of what position you point the holes. Obviously, however, the load is basically straight down on the cam so you want to make sure you have plenty of lubrication at the bottom of the bearing. Since the cam rotates clockwise it also makes sense that you might want to put the oil hole slightly before the bottom and have the rotation of the cam "sweep" the oil down towards the bottom of the bearing.
Long story short, I found it's one of those things that it's easy to spend too much time thinking/worrying about.
Old Dec 18, 2003 | 01:27 AM
TwEaKeDSS's Avatar
that wouldn't make any sense to point the bearing's at 6 o'clock since LT1's have oil holes at the top and the bottom
Old Dec 18, 2003 | 12:07 PM
According to this source....
How To Rebuild .... LT1/LT4 Engines
.... although it isn't "critical" where you put the oil hole, they recommend putting them in the "2-3 o'clock position for optimum oil wedge."
Old Dec 18, 2003 | 03:07 PM
Damon's Avatar
It doesn't matter where the holes in the block are- it matters A LITTLE where you line up the hole in the cam bearing, like Injuneer says.
It might be helpful to explain how oil flows through that part of the engine. Works like this.....
There is a "main oil galley" that runs the length of the block straight above the camshaft. Oil is fed into it at the rear of the block from the oil pump through a series of other passages, through the oil filter, etc. From the main oil galley there are 5 holes going down to each cam bearing. Oil can flow all the way around the OUTSIDE of the cam bearing through a full-circumference groove that goes all the way around it. As long as your cam bearing's oil hole lines up ANYWHERE with this groove, regardless of position, it WILL get oil. What oil does NOT go into the cam bearing continues to the bottom of the groove around the outside of the cam bearing. At the bottom there is another hole- this hole carries the oil down to the main bearings on the crank.
So the oil is fed to the cam bearings FIRST and then down to the mains. Sounds kinda backwards but that's how it works.
Old Jun 2, 2008 | 03:29 AM
InEviTableSS's Avatar
Hey Fred do you know if that is 2-3 o'clock with the engine upside down or right side up?
Old Jun 6, 2008 | 11:16 PM
ENRKyle20's Avatar
free Bump.. I need this info also, I dont know how to subscribe to the thread without posting.
I have to install cam bearing in a week or so on my lt1.
(ok I got it, thanks injuneer)
Old Jun 7, 2008 | 12:15 PM
I don't have the book with me at the moment. But why not just buy it, if you have any intentions at all of rebuilding the engine. I'll take a look when I get home.
To "subscribe" to a thread, use the "Thread Tools" button on the red bar immediately above the first post.
Old Jun 7, 2008 | 04:19 PM
SiNfulSS's Avatar
Here you guys go. Scanned up right from the Rebuild LT1's Book! I recommend it to anyone doing a rebuild. It's got a lot of useful info
CLICK HERE FOR IMAGE
Old Jun 7, 2008 | 06:08 PM
ENRKyle20's Avatar
wow. that does look like a helpful book. I am definatly going to pick that up!
Old Jun 7, 2008 | 07:39 PM
RUDEDOG's Avatar
I line them up with the oil holes in the groove but I don't think it's critical.
Old Jun 8, 2008 | 07:37 AM
rskrause's Avatar
Moderator
"I" line them up wherever the machine shop puts them! I have never done the job myself. Tried it once and found it was a big PITA, maybe because I didn't have the right tool? Anyway, interesting discussion. I enjoyed Damon's description of the oiling system. It is kind of backwards.
Rich
Old Jun 8, 2008 | 10:23 AM
ENRKyle20's Avatar
yea, not having the special tool would make it a PITA.. lol. I picked one up for $42 shipped on ebay. thats less then my machine shop wanted to do it and now I have the tool for next time.
I have done them in school using the right tool and it was easy.. I never tried it without the tool, that would suck. lol
Old Jun 8, 2008 | 06:29 PM
SiNfulSS's Avatar
Yeah it's really not that hard but you definitely have to have a cam bearing install tool. Here is the Proform tool that I used that I picked up from Jegs.
Proform #66794
Jegs part number #778-66794
Old Jun 8, 2008 | 08:37 PM
marshall93z's Avatar
Rich
Huh?
