Cam Bearings? PIC INSIDE
Old Jun 8, 2008 | 10:19 PM
  #16
rskrause's Avatar
Moderator
Originally Posted by marshall93z
Huh?
The way the oiling system works is kind of backwards, like he said.
Rich
Old Jun 10, 2008 | 10:40 AM
  #17
marshall93z's Avatar
Ohhhh... lol!
I thought you were saying HIS description was backwards!
Old Jul 10, 2008 | 09:18 PM
  #18
ENRKyle20's Avatar
Here is some info from another source:
Old Jul 11, 2008 | 12:21 AM
  #19
ENRKyle20's Avatar
question. I decided to use the 10 and 2 mentioned earlier. Its from a book specific to LT/4.
But how deep do you put these?.. if I make the front flush then the back aint flush.. its only this way with #1 and #5.. the center ones line up perfectly.. the one uner the thrust bearing (#5) has like 1/2 and inch area on either side I can move. do I just need to try to line the hold up as close as I can on each end.
wow. I can see I have that one pushed in way to far!.. I need to push it back out.. I didnt even notice until I seen it on camera.. that flash really helps.. I will be taking pictures for myslef when I think they are perfect!.. but still number 5 has so much free room.
Old Jul 13, 2008 | 04:34 PM
  #20
With #5, make sure you leave enough room for the rear plug that goes back in. And don't go too deep the the plug, either. You don't want it hitting the cam!
Old Jul 14, 2008 | 01:46 AM
  #21
ENRKyle20's Avatar
I could just barley see the mark of where the old one was, I just lined it up!.. I think it will work fine. I got the rear plug in.
Old Jul 14, 2008 | 01:48 AM
  #22
ENRKyle20's Avatar
BUT. check this out. here is someons take on it:
The front #1 cam bearing on the LT1 should have the oil holes at 1 and 5 O'clock. The engine is upside down here so you see the holes at 7 and 11 O'clock.
Old Jul 14, 2008 | 06:38 AM
  #23
ENRKyle20's Avatar
and that same person says:
"Cam bearing installation: I draw on the bearing to help with proper oil hole alignment. This is bearing #5 and it needs to have the oil hole at 12 O'clock."
The same as alldata told me
Old Jul 18, 2008 | 01:59 PM
  #24
I marked mine like that, too.
Old Jul 18, 2008 | 02:06 PM
  #25
ENRKyle20's Avatar
i know. but the point is that there is 2 sources here that say one things (and match), and one source that says somehting diffrent.. Guess it reall is not that important. I just went with what the How To Rebuilt Lt1/4 said.. Maybe people have used that book with no problems.
StansZ28
Feb 19, 2015 07:39 AM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
omarECD
Aug 19, 2002 07:28 AM
