anyone make LT1 style TB adapters for the single plane conversion?
Old Oct 11, 2005 | 09:35 PM
dhirocz's Avatar
Been looking for one but I can't fine one. Like to stay with the stock type if possible. Thanks
Old Oct 11, 2005 | 09:55 PM
Dave69Z's Avatar
Re: anyone make LT1 style TB adapters for the single plane conversion?
You might check with Sullivan Performance to see if they might offer their adaptor in that configuration. It would fit under the factory hood if available.
Dave
Old Oct 11, 2005 | 09:59 PM
Mindgame's Avatar
Dave
Yep, seen that one somewhere before.
-Mindgame
Old Oct 12, 2005 | 12:25 AM
atljar's Avatar
Accel / LPE used to make one specific to our style Throttle bodies. Good luck finding one. I tried for about 3 months
EDIT: Hmmm Just looked at their catalog. They have it listed. p/n 74882 , $300+. Also listed as "NEW" product, hahaha. I may try and find out some dimensions for it and throw it on my car. My 90mm TB has just given me issues and more issues.
Old Oct 12, 2005 | 01:06 AM
Jon A's Avatar
Old Oct 12, 2005 | 01:31 AM
SStrokerAce's Avatar
Guys BTDT, it's for a dual 65mm Ford TB. It aint' that simple. I've talked a ton to Scott Sulivan about it.
Bret
Old Oct 12, 2005 | 06:24 PM
Black95Form's Avatar
Atljar: Where did you find the part number 74882? I looked on the accel website with no luck.
Old Oct 12, 2005 | 07:54 PM
Dave69Z's Avatar
Page 20 of DFI Catalog on their Website
Dave
Old Oct 12, 2005 | 09:27 PM
Mindgame's Avatar
Bret
I've only looked at the thing on the net. Never seen one or taken any measurements of my own but I have to wonder.... how hard would it be to weld up the mounting holes & redrill/tap them for a GM TB?
Or *gasp* just use the 65mm F*** throttle body.... or am I just missing something here?
-Mindgame
Old Oct 12, 2005 | 10:31 PM
1racerdude's Avatar
Wilson makes an "L" and I think he has the mounting kit for either Chevy or Ford.
Old Oct 13, 2005 | 01:09 PM
-Mindgame
I have a raw casting in the shop! For the GM TB I have to cut the front of the thing off and weld a new mounting flange on it, barrels full of fun. I should have to do this to the one in the shop this month.
Bret
Old Oct 13, 2005 | 01:45 PM
MPM IV's Avatar
-Mindgame
And theres my question. Would it be feasable to use the 65mm TB?
Old Oct 14, 2005 | 09:11 PM
Mindgame's Avatar
MPM,
I'm still wondering.... why not? The linkage is on the same side and it looks like it'd work. Don't go buying one on my word though. If I did commit to this I'd be prepared to make it work but it all depends on your level of enthusiasm for this kinda thing.
-Mindgame
Old Oct 14, 2005 | 11:51 PM
atljar's Avatar
I dont see why it would be hard to make it work. Im using a ford 90mm on mine.
For the throttle linkage I just took the stock throttle bracket from a lt1 TB and welded it onto the ford unit. Cruise and throttle work fine.
TPS is easily converted (both 5v)
IAC...they make adapters that let you run GM style IAC motor on the 90mm. I would "guess" that you could use the same adapter
Old Oct 15, 2005 | 09:15 AM
Atljar:
What is the problem your setup is having? I am going the same exact route you are and I am concerned.
Michael
