Any tips on installing a vacuum evac. on an LT1? TIA!!!
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
well i am pretty serious about adding an evac. pump to aid in crankcase pressure/ reduction that is. has anyone done it or seen it set up? thanks!
does anyone make an adaptor for the hub on an LT1 if i were to go with the standard moroso setup?
thanks
taner
thanks
taner
i am doing the same thing. dave has a way we are gonna do it i will find out on mon as we are closed the rest of the week. sean
