will i need additional clearancing be required for my new Oliver rods on my stroker?
Old Dec 2, 2003 | 10:19 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Question will i need additional clearancing be required for my new Oliver rods on my stroker?
i should have rotating assembly back tomorrow or next day.
i pulled the Lunati Pro Mod rods out, and am installing the Oliver Billet rods. I beam
is anyone currently runing this setup? obviously it has already been machined for the previous setup, just wondering if there was a difference between the two.(as far as clearancing was concerned)
TIA!
taner
Old Dec 3, 2003 | 10:32 AM
KCFormula's Avatar
With all else being equal if you set the rods on top of eachother and the Oliver Rod is smaller then it should not need additional clearancing. If I remember right the Oliver billet Rods are clerance friendly.
Old Dec 3, 2003 | 11:54 AM
taner's Avatar
KCFormula,
thanks that is what i thought as well, however i didn't check that before dropping the parts off ofor balancing. i will check that once i get the stuff home
Old Dec 5, 2003 | 04:11 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Tanner, I'm running the Oliver I beam 6' rods in my 396. Not sure how wide your old rods were, but here's what i ran into. Had to clearence the block alittle more than my old ealge rods, and then the rods hit on the cam, so had to clearance the rods. Cam is a solid with 640 lift. Wasn't fun at all, but it all pays off in the end, as you well know.
Neal
Old Dec 5, 2003 | 10:31 PM
taner's Avatar
thanks PNYKLR, i compared the lunatis up against mine and they seem to be ok.. i have the 5.85 rods in my motor. but as it goes together it will be checked hey it just seems that i might be able to lighten the car some more
the rods and pistons are a weight savings over the last combo, and i am also installing the ATI balancer.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
IDOXLR8
Aug 6, 2002 12:30 PM
Bill'sWS6
Aug 5, 2002 01:00 PM
