LS1 fuel tank in an LT1 car
I was wondering if the two tanks are interchangeable? LT1 is steel and 15.5 gallons and the LS1 is plastic and 16.5 gallons. The lines and electric conn. look the same.
TIA
Lewis
TIA
Lewis
Depending on where/how the tank was made bigger, one thing that might be an issue is if the pickup on the pump will reach that extra gallon of gas.
Another thing is that this will really mess up responses to the posts "How many miles per tank do you get?".
(another reason not to ask that question)
Rob B 95Z A4
Tech Page
(another reason not to ask that question)------------------
Rob B 95Z A4
Tech Page
Hmmmmmm........added benefit of the weight savings with a plastic tank!
I wonder what the wieght savings will turn out to be?
When you have both tanks sitting on the ground - see if you can somehow weigh them to see for us.
This may turn out to be a good weight reduction mod if it's quite a bit.......
I am not sure, but I think the LS-1 has a different width trunk space than the LT-1. Therefore, the tank might be formed fit for the particular vehicle.
1997 Camaro SS #2948
M6, !CAGS, T-Tops, Tinted Glass
17x9.5 Boyd Coddington Shysters
Eibach Sportline Springs
Flowmaster Exhaust
Pic coming soon!
Flowmaster Exhaust
Pic coming soon!
<font face="Verdana, Arial" size="2">Originally posted by Srper:
</font>
</font>
BLACK 97' RAM-AIR TRANS-AM, DEEP TINT,
LINGENFELTER 383 LT4,
6 SPD. TRANNY, CENTERFORCE CLUTCH, HOOKER LONGTUBES, FLOWMASTER CAT-BACK, STOCK WS6 HIGH POLISHED WHEELS WITH THE REARS WIDENED TO 11 INCHES WEARING 315-35-17
G-FORCE TA's, 2 INCH SUSPENSION DROP VIA EIBACH SPRINGS AND KONI SHOCKS, HARDER DUROMETER BUSHINGS EVERYWHERE ON THE CAR, LS1 CALIPERS AND 13 INCH CROSSED-DRILLED ROTORS, DOUBLE DIAMOND SUB-FRAME CONNECTORS, LG MOTORSPORTS REAR LOWER CONTROL ARMS, STRUT TOWER BRACE, TORQUE ARM, AND ADJUSTABLE PANHARD ROD
its 16.8 gallons.. if you want to be technical..
:P
also the gauge light comes on in an ls1 when it gets to about 3 gallons left.
In my LT1, the E meant get ready to push. 5 times I found myself pushing or walking with my trusty 1 gallon gas can I kept in the trunk.
:P
I don't know if the low fuel light will come on or not, but the extra gallon or so of gas would be a plus. I not think the wieght diff. is going to be too great. I figured my gauge is bad and I also have a large dent on the corner of my tank. I would be able to fix both in one shot.
Lewis
Lewis
Wow.........that much lighter......... As soon as someone knows whether the swap will work, let us know...
