Any tips on installing a vacuum evac. on an LT1? TIA!!!
Old Nov 26, 2003 | 02:54 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Question Any tips on installing a vacuum evac. on an LT1? TIA!!!
well i am pretty serious about adding an evac. pump to aid in crankcase pressure/ reduction that is. has anyone done it or seen it set up? thanks!
does anyone make an adaptor for the hub on an LT1 if i were to go with the standard moroso setup?
thanks
taner
Old Nov 26, 2003 | 05:52 PM
amean94ta's Avatar
hey taner its sean from krs i am doing the same thing. dave has a way we are gonna do it i will find out on mon as we are closed the rest of the week. sean
Old Nov 26, 2003 | 09:59 PM
taner's Avatar
thanks!
Old Dec 4, 2003 | 11:18 PM
amean94ta's Avatar
dave said were going to run it just like on his 512 bbc just have to make a bracket. sorry it took so long
Old Dec 5, 2003 | 05:44 PM
taner's Avatar
that is what i figured i will end up doing if i go this route, i ran without on ebefore so we shall see.
thanks
Jason Short
Jan 19, 2015 06:34 PM
LewisW96
82
Feb 24, 2008 04:49 PM
Zomie
Sep 2, 2002 09:01 PM
Rich_z28
Aug 29, 2002 11:01 PM
