Aluminum Rods for SBC
Old Jan 18, 2004 | 02:37 PM
bad79z28's Avatar
Guys,
I have an opportunity to build my 3rd gen Camaro for a new racing class this year. The class allows aluminum rods. What's your opinions on them? I've never ran them before. Any stumbling blocks to look for? I understand that I'll have to deal with increased thermal expansion. Any particular brand? How much weight could I save over steel rods?
Here are some of the engine specs.
365" sbc w/ Etec 170 heads
4.06" bore/3.52 stroke
6" rod length
flattop pistons
Heads milled for 12.5+ compression
solid lift flat tappet cam
7000 rpm shift points
Do you guys think that there will be a performance gain that is worth the extra hassle of running the al rods?
TIA,
Kevin
Old Jan 18, 2004 | 02:52 PM
NOMAD's Avatar
Re: Aluminum Rods for SBC
TIA,
Kevin
No
-Shannon
Old Jan 18, 2004 | 06:22 PM
AutoRoc's Avatar
Someone's goin Cheap Street Racin' looks like
If it's a street car in any way shape or form I'd stay with a steel piece. Even a "featherweight" design maybe. Then again I don't have any personal experience, just secondhand info from watching local buddies. Sorry! Goodluck.
Old Jan 18, 2004 | 08:14 PM
rskrause's Avatar
Moderator
Aluminum rods are cheap, light, and strong. The problem with them is that they don't last. Most people I know who use them go for maybe 100 runs. Pros replace them much more often. A set of Manley "standard weight" Al rods are in the mid 500gm range and the light weight rods are 50-100gms less. This compares weight and strength wise to a lightweight billet steel rod and is about 1/2 the price. ~$600 v. ~$1,200 dollars. But they are definitely a race only item and will need replacement long before a set of steel rods.
There are various designs and weights available depending on the intended use and other components selected. But in general, a comparable strength aluminum rod will be cheaper, lighter and stronger.
Rich Krause
Old Jan 19, 2004 | 05:22 AM
bad79z28's Avatar
Autoroc,
Yep, I'm looking at racing in the PRO series. They have a new class called Mean Street, which is like Cheap Street, but without the juice. It'll probably start off being a low 11/high 10 second class, then move down to the 10.6 range over the next few months. I'll probably stick with a lightweight steel rod based on what you and rskrause have told me.
Thanks for your information.
Kevin
Old Jan 19, 2004 | 07:35 PM
YOUNGGUN96's Avatar
No way would I go with aluminum rods,imo! I hear that al. rods are mainly for the big cars when they blow so they dont scatter to much stuff and for people with enough $ ta change them very very often. So if you are like me then neither of the 2 is you. I would say to go with a light weight steel rod and gain some strength and lose some hassle!
96SilverRam
Nov 20, 2016 11:19 AM
RUENUF
Mar 13, 2016 03:39 PM
Drtryder
Apr 22, 2015 04:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Bill'sWS6
Aug 5, 2002 01:00 PM
