Aftermarket engine mangement and the 4L60E
Maybe a solution is to change over to the OBDll 12200411 computer. EFI Live supports the 2000 and up L31 Vortec motor that uses the 411 computer. Here are a couple of links for you to browse. In the second link Craig Moates has done quite abit of work with the 12200411 setup.
http://www.thirdgen.org/techboard/tp...-opinions.html
MEGASQUIRT II, its a little bit of work to build, but mine works awesome on my turbo LT1, and i have it piggybacked so my stock gauges and trans stuff (6 speed, reverse lockout and such) still operate. grand total, about $400 and 8 hours of work on the computer, another 5 or so building the harness.
www.megasquirt.info
www.msefi.com
www.diyautotune.com
www.megasquirt.info
www.msefi.com
www.diyautotune.com
www.megasquirt.info
www.msefi.com
www.diyautotune.com
www.megasquirt.info
www.msefi.com
www.diyautotune.com
www.megasquirt.info
www.msefi.com
www.diyautotune.com
www.megasquirt.info
www.msefi.com
www.diyautotune.com
That's a nice job you did w/ your car. Looks good.
I used an OBDII crankshaft position sensor off a 96+ LT1 for a trigger, its an even 4x sensor. Use the hall settings in megatune to make this work. I then installed the optional vb921 high current ignition driver circuit, and it controls the coil directly. Output for (-) side of the coil comes directly from the megasquirt, or, this output can go to an MSD box. Uses a standard universal 12v cylinder coil.
as far as issues, ive had many, but most have to do with my 160lb injectors on a "street" car...idles real rich
A crank trigger will work, i take it your talking about an msd type flying magnet system...that will work. MS will only do batch fire or bank to bank. Im running bank to bank, but i see no downfall to doing it this way.
Kevin,
When we go to do your ignition we will use the ignition module mode of MS2. Because you have an LTCC that gets its signal directly from the opti, It will be used for ignition. The only thing Megasquirt needs is a refrence signal to know where the engine is fireing. This is strictly so it knows when to fire the injectors and when to fire the plugs. (most of the work is done by the LTCC.)
Kevin,
I was talking bout the flying magnent setup.. thanks... So with a batch firing scheme really the only thing the opti is good for then is driving the tach? The MS doesn't use the reference signal correct?
Will, I used to live in Marietta I was stationed at NAS Atlanta from 94-98.
and i was in elementry school and middle school from 94-98...haha, but, ive lived here all my life, where abouts marietta did you live?
Jan 5, 2015 07:14 PM
hotrodyou1
Dec 20, 2014 10:05 PM
