Advancing the cam to 5-6 dgrees
Old Nov 8, 2005 | 06:21 PM
Z28barnett's Avatar
I am going to be installing a CC305 cam. In an 1995 LT1. I was wondering if I advanced the cam from the stock 4 degrees to 6 degrees would that give me more bottom end torque.
Or would it just kill the upper end and do little for the lower end torque.
I realize there would be other issues with the igntion and the injector timing.
If those were not problems what could I expect?
Z28
Old Nov 8, 2005 | 09:30 PM
AdioSS's Avatar
West South Central Moderator
Re: Advancing the cam to 5-6 dgrees
(It) would ... just kill the upper end and do little for the lower end torque.
Old Nov 8, 2005 | 10:13 PM
rskrause's Avatar
Moderator
I doubt you would notice much difference, assuming you mean two additional degrees of advance beyond the four already ground into the cam. If you mean six MORE degrees, for a total of ten degrees of advance, I think it would not like that at all.
Rich
Old Nov 9, 2005 | 07:06 PM
Z28barnett's Avatar
Thanks for the info guys.
I was talking about 2 degrees beyond what was ground into the cam.
I was guessing that the MFG might have already worked out the best compromise on the CC305 at 4 degrees advanced.
I was thinking about this because of the MSD billet LT1 dist. It will not be out untill at least FEB. It has the +/- 5 degree adjustment so you could correct the dist for a 2 degree cam timing change.
I am concerned that I will give up too much low end, get used to the engine lugging so well.
But the cam swap will need to be before Feb so I can't do what I wanted easily. Best leave it alone.
Z28
Noenav
Mar 1, 2019 07:38 AM
armedtrigger
Feb 24, 2015 08:30 PM
chuyz28
Feb 19, 2015 12:50 AM
Injuneer
Dec 15, 2014 09:36 AM
Noenav
Dec 6, 2014 07:35 PM
