6 in rod?
Old Feb 3, 2005 | 05:57 PM
"White Knight"'s Avatar
6 in rod?
Alright the question is.....can a piston 4.030 bore designed for a 355 with 6in rod fit anything else? (it's a blower piston -24cc) Would it be able to be used in a 383 set-up? if you used a 383 crank that used 6 in rods?
Old Feb 3, 2005 | 06:27 PM
Re: 6 in rod?
This probably effects the piston stability in the cylinder though wouldn't it?? hmmm....the reason i ask is i am looking to maybe buying a set quite cheaply and need to know if i can use them in a 383....and have it work correctly.
Old Feb 3, 2005 | 07:04 PM
WS6T3RROR's Avatar
Re: 6 in rod?
the only obvious thing i see it being put into easily besides its intended use is a 383 with a 5.85 rod some minor block decking to get the quench right and it should be good. depends on the actual compression hieght of the piston though but should be close anyway.
Old Feb 3, 2005 | 07:11 PM
jimlab's Avatar
Re: 6 in rod?
With a shorter connecting rod, sure. For example...
383 crank = 3.75" stroke
0.5 * 3.75 (half stroke) = 1.875" + 6" (rod) = 7.875"
LT1 deck height = ~9.000-9.025"
9.025" - 7.875" = ~1.15" piston compression height
355 crank = 3.48" stroke
0.5 * 3.48 = 1.74" + 6" = 7.74"
9.025" - 7.74" = ~1.285"
So if you use the 355 piston in a 383 with a 6.0" rod, it will extend ~0.135" above the top of the deck at TDC. Not particularly good for your engine.
However, you could use 5.85" rods and have the block decked ~0.015" depending on what your builder recommends and the compression height of the piston in question.
The same 383 with a 5.85" rod...
0.5 * 3.75" = 1.875" + 5.85" = 7.725"
9.010" - 7.725" = 1.285"
Old Feb 3, 2005 | 08:39 PM
OldSStroker's Avatar
Re: 6 in rod?
Wish I'd said that.
http://web.camaross.com/forums/showthread.php?t=338323
Old Feb 3, 2005 | 10:27 PM
jimlab's Avatar
Re: 6 in rod?
Originally Posted by OldSStroker
Wish I'd said that.
Looks like you did. I didn't know there were parallel threads.
Old Feb 3, 2005 | 11:09 PM
Mikey 97Z M6's Avatar
Re: 6 in rod?
And almost an identical response to a different question over here earlier today. Must be the question of the day lol.... :
http://www.ls1tech.com/forums/showthread.php?t=270244
Jim, did you ever get your LT1 RX7 running?
Mike
Old Feb 4, 2005 | 12:02 AM
jimlab's Avatar
Re: 6 in rod?
Nope, still working on it. A little bit here, a little bit there.
Old Feb 4, 2005 | 02:18 PM
Re: 6 in rod?
Man that thing's gonna be a beast when you're done. You still got the Z06?
BTW, I bought your 200 mile LT1 block from ya a couple years ago, just in case you were wondering.
Whiteknight, sorry to highjack your post.
Mike
Old Feb 4, 2005 | 04:22 PM
jimlab's Avatar
Re: 6 in rod?
Nope, traded the Z06 for a baby and a Lumina.
I think the thread had pretty much run its course, especially since his question got answered in more than one forum...
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Sep 15, 2015 11:07 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
