377 stroker
Old Nov 21, 2002 | 12:42 PM
  #16
rskrause's Avatar
Moderator
81mouse is right on. For most setups, it makes no difference. If you are building an all out, high rev racing motor then a long rod is better. Otherwise, don't sweat it.
Rich Krause
Old Nov 21, 2002 | 06:07 PM
  #17
VentsWoker's Avatar
One specific... the use of the short deck big-block Chevrolet engine. If you're into BBC then you know how popular they are with the race crowd. Shorter pushrods (less weight in the valvetrain), shorter rods (less weight), etc.
In acceleration I'm talking piston. I didn't say that the only reason was max piston speed. Please go back and read what I said in my first response.
Most guys are running Powerglides (I raise my hand) in their race cars. One thing you'll find out about running a 2-speed tranny in a race car is that the engine has to be built a little diff then those running the 3-speeds. More rpm drop between the gears, more velocity is needed through the intake port, short rod helps in creating more velocity and car can run stronger and to a higher rpm because it can tolerate more cylinder head. Believe me, I've seen it first hand in my own cars.
Do you wanna debate this some more?
i see you're point mr. smartie pants, my mistake. i think that i would go w/ a similar setup w/ a 1320 car on a power glide. however, he made no mention to what setup he was running.
At least we've determined that it's the rod stroke ratio.
But please be more specific... what is the formula? How would you go about determining an "optimum" rod/stroke ratio? I'm all ears.
formula? it's kinda comomon sense, but "optimum" hinges on the combo. as you mentioned the bbc works well w/ shorter rods simply because of the way the motor has been done to compensate for the 2 speed, lower gears, ect...
as i mentioned, a diffrent combo requires all factors to be taken into account, say our boy w/ the 377 stroker, probably be a street car and wont see 80% of the max pistion speed on the street, but lets say he runs it at the track on the weekends w/ nitrous. if it was me i'd go w/ the 5.7 rod verses the 5.85 or the 6.0 or bigger. the 5.7 nets him a 1.52 Ratio and will premote better cyllinder filling on the bottle. not that this will make much diffrence alone but every little bit helps. im not arguing the rod length dabate here, i think it was merely my un-edjumicated response about pistion acceleration that started all this. would you agree Mr Mindgame?
Old Nov 21, 2002 | 11:23 PM
  #18
99huggerorangeZ's Avatar
Question
i dont want a 8500 rpm v8 i am staying aroung 6500 but the pistons i am getting from JE said to use a 6.0 rod with a 3.750 stroke and 700cc heads to get a CR of 10.3:1
so it doesnt matter if i get a 5.7 or 6.0in rod for a 6500rpm engine
butif je says to use a 6.0 with that piston should i
Old Nov 21, 2002 | 11:26 PM
  #19
SStrokerAce's Avatar
but if je says to use a 6.0 with that piston should i
Yes, you have to use a 6.0" rod with it if you want any compression.
So go with the 6.0" rod.
That's all i'm gonna say before being called Mr Smartie Pants.
Bret
Old Nov 21, 2002 | 11:27 PM
  #20
VentsWoker's Avatar
lol.. sarcasam is tough to carch over the net.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
