11.8:1 on 91 pump gas
Even the most radical NA builds (way beyond this run of the mill 383) just adjust lookup tables and switch DTC's on/off, there's typically no "coding" or algorythm adjustments needed (the OEM PCM is VERY robust and makes table adjustments cover nearly every possibility). There are a few exceptions of course (like a BLM-locker), but most everything is "just" a matter of changing the right table value, flag.
There are very few advantages to disabling the O2 sensors... my money's on this 383 just having a normal spark/fuel change, no change on O2 operation.
As mentioned, you should have no problem with detonation. higher altitudes can use lower octane, and even if he DID drive it to sea level on 1 tank
he HAS knock sensors... they can adjust spark to compensate until the next fill up. (but honestly my build probably has more compression than this 383 and we run 91 octane at sea level ALL the time. Nothing spectatular if you have functional O2's and knock sensor (and a big enough cam
I prefer to not ***ume how the car in question was tuned, especially since that could lead to the OP getting screwed.
This is all beyond the point however... if it's fine in texas with 93, it'll be fine in colorado with 91. Like I said, we run more compression at sea level in this area without issues.
Magenta_Hearts
Mar 22, 2015 03:36 PM
dmaastr
9
Jul 1, 2002 02:22 PM
