02 issue also posted in tuning not sure where it belongs
Old Aug 25, 2007 | 02:59 PM
jasonisdn's Avatar
http://web.camaross.com/forums/showthread.php?t=539707
Old Aug 25, 2007 | 06:21 PM
jasonisdn's Avatar
does it look like my injectors are staying open to long at idle?
Old Aug 28, 2007 | 07:00 PM
jasonisdn's Avatar
http://www.mediafire.com/download.php?5k2z9zm5vgy#
thanks to user803815 on the LT1 edit mailing list , i found the problem. The fuel injector circuit was to weak to feed the voltage needed for the injectors. i ran a 12 gauge wire and feed it off a relay that is feeding the versafueler. I also went back, after the 02's readings were good, and cut all the crimp style fittings out and soldered all the connections.
PCLZ28
Dec 24, 2015 05:19 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
derty
Jul 16, 2002 12:20 PM
