New Single Plane Question
Old Aug 21, 2007 | 08:39 PM
RRR's Avatar
RRR
anyone done a dual plane conversion? pros/cons
also, everyone who knows about the conversion know the inherent problems with hood clearance. well I was working on my Dad's 4.6l ford today and took a look at the upper plenum - looked like it could work and about half as high just a guess though.
anyhoo here is a link to the style tb and upper plenum I am talking about. I think the max size they make them in is 75mm but I would be fine with that if it could be made to work for cheap.
http://www.rpmoutlet.com/newv8ma.htm
Old Aug 22, 2007 | 01:19 AM
AdioSS's Avatar
West South Central Moderator
I think that a dual-plane like the Performer RPM would be a good alternative to the other options for more mildly modded cars with less gear and converter. A heavy car like mine or a convert would appreciate the difference even more.
Old Aug 22, 2007 | 05:40 PM
rskrause's Avatar
Moderator
The main pupose of a dual plane is lost on an EFI car. There is no need to send a strong signal to a carb that is not there. Dual plane is for carbs.
Rich
Old Aug 22, 2007 | 09:00 PM
RRR's Avatar
RRR
Rich
Little lost on the "strong signal" but the reason I wanted to do the dual plane was because the effective plenum is split which as I understand it helps promote more low end power vs. a single plane. the range of the duals is around 1500-6700 perfect for my cam and heads. the range of a super vic is around 3500-8500 if i remember correctly or thereabouts. I would rather have that extra rpm a super vic would provide down low since my car is mostly used on the street and I want it to be fun to drive hence the reason I am leaning more toward a dual plane. I would appreciate thoughts on if this would be worthwhile.
description found via search posted by angel71rs:
Single plane are just what they say; all the runners are on one common plane feeding off a common plenum. Advantages: all intake ports can pull flow from all 4 barrels of the carb = more possible hp. Disadvantage: all that volume is harder to get moving at low rpm, so low end response is less than a dual plane. Also short runners tend to be tuned to higher rpm. The tunnel ram intakes modified this with longer runners. Longer runners change where the intake pulses resonate.
Dual planes have the runners on 2 planes, one set over, the other set under. each set sucking off 2 barrels. Less volume to get moving combined with the longer runners of this design = better lower rpm response. Plus the greater velocity helps keep the fuel from falling out of suspension in the mix coming off the carb at lower rpms. The Performers are this type.
Old Aug 22, 2007 | 09:46 PM
FASTFATBOY's Avatar
Put a Victor Jr on it then, A "strong signal" is the vacuum signal for the carb to work well, efi does not need it.
David
Old Aug 22, 2007 | 10:59 PM
RRR's Avatar
RRR
David
I thought victor jr's were for even higher rpm's due to their shorter runners vs. super vic? The reason I am interested in this is to try to fatten the curve from 1500 to 6500 not concerned if it peaks exactly where the lt1 manifold does since I am trying to find more under the curve. dual plane seems like it would deliver in the range I use the car in but not having any experience with them on efi I am at a loss. I did see a dyno of a 355 super vic that lost power below 6k compared to a ported lt4 that's when the idea of doing a dual plane came along.
Old Aug 24, 2007 | 05:33 PM
RickWI's Avatar
It is impossible to get injector firing angles installed correctly in a dual plane setup. You're thoughts though are right on the money. The intake choice with EFI will have a profound affect on the power curve, just like EFI. If you want excellent torque as well as very good top end use the Holley Stealth Ram intake and matching TB.
I also would not run an elbow and TB like that on a standard style single plane intake, both Marren Fuel Injection and Accel make very nice low profile standard style 4150 and 4500 TB's that would work better.
Old Aug 24, 2007 | 05:40 PM
FASTFATBOY's Avatar
There are more factors that determine torque besides intake runner length. Port volume, camshaft, VE and header size also play a big role.
Ed Wright and Rick Abare both made good power/torque with a stock LT1 style intake.
David
Old Aug 30, 2007 | 02:49 PM
WS6 TA's Avatar
the bolt flange/opening for the ford assembly is much much smaller then a 4bbl carb opening, you'd end up having to make an adaptor plate to make it work, making it as tall as most of the "normal" elbows
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Dmonty
Jun 2, 2015 11:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
