.005 piston clearance causing slap and perhaps causing false knock ....any cure?
Old Mar 8, 2005 | 10:38 PM
  #16
canbaufo's Avatar
Re: .005 piston clearance causing slap and perhaps causing false knock ....any cure?
Originally Posted by jonaddis84
I dont know the expansion properties of the pistons you are running, or even pretend to. But if you cant get rid of the knock, try running the engine hotter, like at factory temp, assuming you probably have a 160stat in it.
Good idea. Some claim it is better to run a 180 stat anyway. I will have to consider that if I run out of options.
Old Mar 14, 2005 | 11:57 AM
  #17
94LT1_89TTA's Avatar
I am helping Charlie sort out this new combination, and I wanted to post the solution to this one.
It is true that the shortblock has audible piston slap particularly cold, and since the builder didn't check it, we have no way of knowing what the actual clearance is, but fortunately that was not the issue.
The car also had an ABS and airbag light when it came to me that I hadn't really tried too hard to find. Yesterday, the abs and airbag lights went off, but the scanmaster reported knock also went away at precisely the same time.... All three issues returned next time I started it.
I did a search for abs and airbag lights, and got a thread directing me to the chassis ground on the right inner fender. Sure enough it was all connected, but not securely.
The lights are off, and the retard is gone. Millivolts are funny things sometimes. The poor ground must have caused a backfeed into the KS circuit. I will look at the schematics tonight and try to fully understand it, but I wanted to post this under the category of "first time I've seen that" for you guys to file away mentally for future use.
Roger
Old Mar 14, 2005 | 02:07 PM
  #18
I'm definitely going to file this one away in the data bank.
Old Mar 14, 2005 | 03:40 PM
  #19
1stz28's Avatar
It always amazes me how many problems can be caused by poor electrical connections...and as you mentioned especially when dealing with mv. Thanks for the heads-up on the fix.
Old Mar 14, 2005 | 04:03 PM
  #20
marshall93z's Avatar
same here...
Old Mar 15, 2005 | 10:41 PM
  #21
canbaufo's Avatar
Cool Re: .005 piston clearance causing slap and perhaps causing false knock ....any cure?
Roger
Roger, there seems to be no limit to your ability. Just want to give a show of appreciation for you here. Rog figured out the main problem w/my new engine (bad cam grind) which had baffled my usual mechanic and I for sometime. It has been well worth the pricey U-Haul trip to get it up to you for your fixes. You're the man Rog is humble but he's truly a "guru" at design and troubleshooting (among other talents).
Old Mar 16, 2005 | 01:01 AM
  #22
SStrokerAce's Avatar
Wow good find!, we should sticky this thread.
No fix that we should have a thread archive.... maybe a good place to put the really good formal posts so that we could rehash old topics over time too.
Old Mar 24, 2005 | 12:58 AM
  #23
Blownbird355's Avatar
Where the retard go
carl.froehlich
Mar 13, 2015 12:38 AM
pimpss96
Feb 12, 2015 01:28 PM
Gtpguy
Jan 26, 2015 04:50 PM
Nostang 96z
Sep 10, 2002 08:54 PM
