*caution* lunati cranks are bad
Old Dec 4, 2003 | 09:02 PM
  #16
Hot Rod Hawk's Avatar
The second part of your statement would be the correct answer, If I remember correctly Rich.
Old Dec 4, 2003 | 09:06 PM
  #17
rskrause's Avatar
Moderator
Thanks, that's what I thought but wasn't sure.
Rich
Old Dec 4, 2003 | 09:20 PM
  #18
got_hp?'s Avatar
just a thought...........before starting a 100 page thread with no answers...........why doesnt someone else call lunati and find out (even ask for allison). im sure it would take no more than 5 minutes.
id do it, but i dont have the technical knowledge of you guys to be able to ask the right questions.
Old Dec 4, 2003 | 09:47 PM
  #19
amean94ta's Avatar
Originally posted by Steve in Seattle
<smirk> You've corrected him on spelling a "Lunati", then use grammer like this. (not trying to be mean... just pointing out that proof-reading a message board post is low on most people's priorities... even when they think it isn't).
On a more serious note, I wonder why a heat-treating process used for all crank journals would only fail in the same spot (1st and 2nd counterweights)... and not randomly.
The confusion grows more with the info Dennis posted that Lunati doesn't even heat-treat their cranks at all...
Are you sure the block mains are all in alignment? weird that both would fail in the same spot unless it was block machining or assembly error. If Lunati admits the hardening process was messed up I suppose its fair to say, although I havn't talked to them... it just sounded weird (and I think you need to read Injeneer's post again... I don't think he was trying to be rude, he asked the same questions that were going through my head )
forgot to put them like this "them" sorry
Old Dec 5, 2003 | 07:34 AM
  #20
airflowdevelop's Avatar
Rich,
This process is for case alignment only. Primary reason is wear resistance with higher cylinder loads. Normally the problem you are seeing with the 1/2 journal failure is caused by improper main bearing oil clearances.
Dennis
Old Dec 5, 2003 | 09:08 AM
  #21
rskrause's Avatar
Moderator
Originally posted by airflowdevelop
Rich,
Dennis
Thanks! Knowledge is POWER!
Rich
Old Dec 5, 2003 | 09:31 AM
  #22
Originally posted by amean94ta
1.) Krs machining in erie, pa thats my shop but did not post because i am not a paid advertiser
2.) Yes "them" is lunati not lunatti
3.) It broke between the 1st and second counter weight on both cranks under normal driving.
4.) I dont know who allison is them gave her to me when i called.
(side note) I thought of all people you would not act like a jerk as you are one of the most respected guys on this board along with rkrouse. If you want more answers call them yourself i was just trying to be helpful
You came on, flamed a generally respectable vendor, and posted no backup. You also posted the info on all the other forums. All I asked for was more "advanced" info, to give your post credibility. Your followup post, while informative, was "lacking".... My intent was not to challenge you, but to make the info you posted more useful.
Maybe I'm supposed to know from your screen name what your background is, who "we" is, how credible the whole thing was, but my crystal ball is a little fuzzy. My sincere apologies.
If you feel I'm being a jerk, you're entitled to your opinion.
Have a nice day
Old Dec 14, 2003 | 03:16 PM
  #23
davepl's Avatar
I don't have anything to contribute here (and my crank is a Cola), but I'd really suggest a moderator at a minimum change the title of this thread (and the various cross posted ones) so its not so inflammatory against Lunati.
You can't unring a bell, and I don't see anything in this thread that justifies potentially trashing a mfr so severely without any data.
Dave
Old Dec 14, 2003 | 04:26 PM
  #24
Flip94ta's Avatar
So if this guy. who works at KRS as a machinist, which is a decent shop, tells me that two $700 cranks broke in two weeks, then I knowing his back ground tend to believe they are JUNK. His people skills arent the best but these cranks have cost some people thousands of dollars. Thanks for the heads up.
Old Dec 14, 2003 | 06:17 PM
  #25
amean94ta's Avatar
Still waiting to hear if your gonna come back.(flip) things between me and norb are gonna heat up real good this year. His bbc 454 with a 200 shot against my lt1 ta with a 300 shot
Old Dec 15, 2003 | 09:29 AM
  #26
Flip94ta's Avatar
Actually he has a 427 thats .60 over, but whats a couple inches right? I should not devulge all his secrets but he does weigh less than 3000lbs.
As for Lunati and Holley, they are a dissappointment. I take it they did not make any effort to contact the customers who recieved the cranks. That pisses me off, someone could be killed by a bad crank, let alone out of a ton of money in a engine and tranny, and they dont tell anyone? I can only guess at how long they have known, but I would bet its been long enough that they could have mailed their customers a letter with the problem. Lets talk about Holley some more. Norbs Dad with the 455 regal had a Holley carb stick and it sent him into the porch of a house on 12th st. It could and almost did kill him. The car was totaled, he had to buy it back. They were nice enough to send him a new carb. My own experience with Holley wasnt that great. My beautiful 58mm TB set off engine codes when I installed it while I was away at school. Luckily the DIY shop on post rented out the scantool for $3 to me. What if I had to go somewhere to get it scanned, thats not cheap. I got on here and looked around and many people with their throttle bodies had the same problem. I called them up after three weeks of frustration and the tech said slot the holes in the tps and it will be good. Nice quality huh? He feed me a line about how GM's patents prevent them from making an exact replica. Gee I didnt know GM made a CNC 58mm TB. If those guys were at the track and the cranks broke and rear wheels locked or or oil and water ran all over the track and the guy or gal was killed what would they have done then? I think some class action lawsuits may make Holley/Lunati a more responsible manufacturer. Lets be honest here, alot of automotive aftermarket companies do us wrong. With long wait times, false HP gains, and poor engineering. And we sit here and take it. Jose has been trying to get his turbo setup right for 2 years, my buddy steve has gone 9 months so far. My own engine took two months than they said and was $600 over their estimate. I know its costs money to go fast, but it doesnt mean I want to be treated like crap.
Old Dec 15, 2003 | 04:47 PM
  #27
amean94ta's Avatar
I had a brain fart. he does have a 427 my cousin just put on the n20 kit. me and norb are good friends so it will be a friendly rivalry so hurry up and make it back ok
Old Dec 17, 2003 | 11:06 AM
  #28
Maldo's Avatar
As anyone contact Lunti to get an official or UN-official answer from someone there pertaining this issue.
Old Dec 18, 2003 | 03:01 PM
  #29
mnorwood's Avatar
I've seen this thread for quite a while but this is the first time I've read it. I had a major impression that lunati was bad until I actually read it-now I'm undecided.
It could have been the crank or something else, and people have posted positive things about the engine builder and the crank manufacturer.
I really think (as someone else pointed out) that a moderator should change the title of this thread or close the thread. There's nothing conclusive here, just a constant smear campaign caused by having the name of the thread floating around.
Old Jan 18, 2004 | 09:21 PM
  #30
nosfed's Avatar
[DELETED]
