window problem
Old May 6, 2004 | 07:40 PM
lordmetalz28's Avatar
window problem
well my passanger window is not going down, but before i rip open my door is there a fuse a regulator or something to check my driver window still works are there one fuse for both or are they separate , just wondering before i rip my door open
Old May 7, 2004 | 12:20 PM
Z28SORR's Avatar
No seperate fuses. 90% of the time it's the motor. If you want to do something first, you can check for voltage at the door switch with a multimeter.
Old May 8, 2004 | 08:58 PM
sweet, the new motor comes with bolts so i dont have to **** with rivets, awesome awesome, how big of a job am i in for
Old May 9, 2004 | 12:48 AM
IROC-T's Avatar
Should be able to kick it out in an hour ,hour and a half ,that gives you time to clean up and lube everything while your in there. Oh, and a sharp drill bit!
Old May 9, 2004 | 12:55 PM
what parts do i exactly have to lube up
Old May 9, 2004 | 01:57 PM
IROC-T's Avatar
Any parts that move ,when I say lube I mean what ever type of lube that is needed for the paticular piece that your lubing ,ie. silcone for window channels,lithium for metal,etc. .
Keenan
Jan 19, 2023 12:24 PM
NewsBot
Apr 11, 2015 11:44 AM
guruerror
Mar 4, 2015 06:25 PM
warmeck
Feb 2, 2015 12:44 AM
The Seer
Nov 20, 2014 06:32 AM
