why is my lg4 doing this
Old Jul 5, 2004 | 11:25 AM
CamaroZ28Coupe's Avatar
aright my car starts and goes to fast idle at a little below 2000rpm then i can kick it down to around 1300rpm then it will finally kick down to a little bit above 500, thats when its cold
so i drive around and it will idle dead on around 600 (chiltons says 575 for auto, thats in drive right?)
but...... after the car is warmed up for some reason when i go to put it in park it jumps to a faster idle speed like 750, 800 and its odd becasue it will do little slow incrreases in rpm and bump to around 1000 the longer i leave it on sometimes, if i try and kick it down it wont (prob becasue its warmed up) it just goes back to around 1000
i was thinking the suspects could be the idle load compensator, mix controll solenoid being funny, or a small vacuum leak
any fixes or ideas?
Old Jul 6, 2004 | 12:51 PM
angel71rs's Avatar
I vote for vacuum leak. Pop off air cleaner and check with a can of carb cleaner with small squirts in suspected areas. You can also use unlit propane torch. Most likely cause is a cracked vacuum hose, especially at a turn.
Old Jul 6, 2004 | 02:50 PM
yep some of the hoses are hard as a rock and cracking, i replaced a couple and it seemed to get a little better
question: why does it take a minuit or two to start climbing, (it doesnt go up right away)
isnt carb cleaner corosive to the rubber lines?
Old Jul 6, 2004 | 03:53 PM
Marc 85Z28's Avatar
I agree with angel71rs. A 20+ year old car will have its problems, and vacuum leaks are very common. Even if you can't detect a leak with the old carb cleaner method, its a good idea to go through the entire system and replace all vacuum hoses and hard lines. It made a big difference with mine.
You can eliminate a choke problem by removing the aircleaner lid with the car running and exhibiting the symptoms. Inspect the choke. Once warm, it should be fully open. I've seen them stick before.
viper01
Feb 5, 2004 03:06 PM
chevyman502bb
9
Jan 16, 2004 10:50 AM
chevyman502bb
Jan 14, 2004 01:27 PM
85Berlinetta
Apr 9, 2003 11:32 PM
1BadRS
Sep 18, 2002 12:29 AM
