Where can i get a head light motor rebuild?!?!
Old Aug 19, 2005 | 01:21 PM
Runin2Nite's Avatar
i've been looking everywhere and calling alot of local shops with no luck. do rebuild kits even exist??? or do i need to buy a new motor??
i need the kit for an '88 bird
Old Aug 19, 2005 | 03:11 PM
Zepher's Avatar
Re: Where can i get a head light motor rebuild?!?!
does the motor still run but the light doesn't come up?
If so, you can get a bushing rebuild kit for about $25 from TDS.
http://www.top-downsolutions.com/pro...9bca8f55ee0063
Old Aug 19, 2005 | 04:38 PM
Runin2Nite's Avatar
yea i took it apart and adjusted the bushing (there is nothing left of it) and i got it to turn. thats all i need is new bushings.
Old Aug 19, 2005 | 04:43 PM
Runin2Nite's Avatar
it says used... is this rebuilt or some guy sellin off stuff with a little life left in it??? the bushings is exaclty what i need
Old Aug 19, 2005 | 04:50 PM
Zepher's Avatar
the link to the bushing repair kit is for the new bushings,
should say this,
Deluxe headlight repair kit
[209280] $20.00
Old Aug 19, 2005 | 05:01 PM
Runin2Nite's Avatar
yea thats with the white lube and gaskets and stuff....theres another thing on there that just has the bushings.... it says used....it has to be better then what i got not rite??? i ordered it, like 15 bux with shipping. thanks for the link i've been going crazy looking for that part!!
Old Aug 19, 2005 | 06:50 PM
Zepher's Avatar
I couldn't find the used stuff, but there was a link for the 3 bushings by themselves for $6.25.
Old Aug 19, 2005 | 11:12 PM
quickchicken's Avatar
drop 3 15/32 bearings in there and ya wont hafta worry about ANYTHING crumbeling again. i did this almost 4 years ago and all is good and smooth in my motors. i used white lithium spray grease in the gear area.
iv also built a few other folks headlight motors and all is good with theirs as well.
Old Aug 20, 2005 | 01:44 AM
Runin2Nite's Avatar
where do yoiu get 3 15/32 bearings and how does that work????
Old Aug 20, 2005 | 08:59 AM
go to your local bearing supply and ask for them, that is about the only place to get them unless your local hardware store is better than avg. there is a size smaller than 15/32 that will work. they are larger than the avg hardware store will carry. but 15/32 are the best fitting .
drop the bearings in the plastic gear, 1 in each clover leaf and put it back together like ya took it apart.
yas got any more ques ,ask.
Jazsun
Dec 29, 2014 12:14 PM
NewsBot
Dec 28, 2014 06:20 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
