what kind of gas is best? regular or premium
Old May 2, 2004 | 04:10 PM
  #16
WhiteKid's Avatar
Well with all this talk I think im just gonna stick to my 89 octane Ive been using.
Old May 2, 2004 | 07:07 PM
  #17
aklim's Avatar
The best thing to do is to test it out. Make sure the car is running perfectly and load it with 87 and use a scantool to see the knock counts when you accelerate. Compare that with 89 and then 92
Old May 3, 2004 | 05:32 PM
  #18
Pasky's Avatar
Originally posted by Marc 85Z28
I agree. Always run the lowest octane rating that the engine will allow. Any audible pinging and you should either adjust the timing or increase octane. Minor undetectable detonation the ECM will take care of.
Much better gas mileage from running higher octane? That's a new one on me
I have my 85 owner's manual, and there's no mention of the need to run higher octane gasoline for the TPI cars.
Its not the octane, its the premium gas seems to be of higher quality, I can usually get about 50-60 more miles out of a full tank of premium over the cheapo 87. Pays for itself.
Old May 3, 2004 | 05:45 PM
  #19
trackbird's Avatar
In most cases, your results would be due to the computer running less or no knock retard with premium. That is where the mileage usually comes from. Fuel, is fuel. It contains the same amount of thermal energy per gallon, it is typically timing that accounts for the difference.
If you follow Aklim's suggestion, I suspect you will explain your mileage increase.
Old May 4, 2004 | 12:55 AM
  #20
aklim's Avatar
Knocking can occure even if you cannot hear it. It might be knocking all day long but audiable to the KS only. When the KS senses the knock it retards the timing. Less timing, less power and so you waste more fuel to get the same results.
May 8, 2015 11:30 AM
May 1, 2015 01:14 PM
blac94Z
Nov 24, 2014 07:12 PM
simple
Aug 11, 2002 11:56 AM
DarkHorse
Aug 3, 2002 10:17 PM
