What engine to start with?
Old Jun 26, 2005 | 09:53 AM
  #16
YARDofSTUF's Avatar
Re: What engine to start with?
Originally Posted by 91-Z28-L98
Its tough to get 450 hp while staying emissions legal with no forced induction or nitrous on a small block.
So going forced induction would possibly make it easier?
still be emisions legal? but i assume cost skyrockets.
Old Jun 26, 2005 | 05:38 PM
  #17
91-Z28-L98's Avatar
The problem with forced induction is that our heads weren't made for it. The compression is a little high and iron heads don't conduct off heat as well so detonation becomes a problem. Also, at 450 hp you will need a new bottom end (with NA, nitrous, or forced induction). So yeah, cost goes up because you probably will need new low compression big valve heads anyway plus the cost of the supercharger kit which will probably be around $3500 with pipes and intercooler (for a turbo kit, forget it). You may be able to get 450 hp on stock heads supercharged, but I would talk to someone who has already accomplished this first and copy what they do. Any way you go will probably cost big money for 450 hp street legal.
Old Jun 27, 2005 | 02:55 AM
  #18
YARDofSTUF's Avatar
Guess I need to move over to the ls1 section. looks liek the ls1 or ls6 is where i should start.
Old Jun 27, 2005 | 08:55 AM
  #19
91-Z28-L98's Avatar
LS1 probably wont be cheaper. The engine will run you around 3k plus it doesn't exactly slide right into our engine bays. I like the LS1 because it is very durable and supports upgrades well. Look into all of your options or lower your hp requirements if cost is really an issue.
Old Jun 27, 2005 | 09:02 AM
  #20
YARDofSTUF's Avatar
Where have you seen teh LS1 for 3k?
Old Jun 27, 2005 | 10:00 AM
  #21
Tru2Chevy's Avatar
eBay - seller name Fparts (Contemporary Corvette in Bristol,PA)
These guys are about 20 minutes from me, and a friend of mine bought an LS1/T56 combo for $4500 from them with all wiring, PCM, shifter and pedals.
- Justin
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
Jul 4, 2005 05:00 PM
