Air pump solenoid location
Old Jun 24, 2005 | 08:06 PM
zrs's Avatar
zrs
Anyone know the location of the air pump solenoid on a 92 RS Camaro? Looking to install heated O2 sensor.
Old Jun 24, 2005 | 09:42 PM
Ben91RS's Avatar
Re: Air pump solenoid location
Both of the air pump solenoids are located in a large black box on the passenger side of the motor, right on top of the valve cover. You'll see 1 wire loom and about 5 large hoses coming out of it. Here's a couple of pictures I found for reference:
In this one, it's in the bottom right hand corner of the picture:
http://images.cardomain.com/member_i...83_26_full.jpg
And in this one, there's a front view of it right above the valve cover and behind that strut tower brace:
http://images.cardomain.com/member_i...83_27_full.jpg
Then you just need to pry that front cover off, and you'll see 2 solenoids, the air select valve and the air diverter valve.
Why do you need to know the location of the AIR pump solenoids if your installing a heated O2 sensor? Trying to find an existing 12V source? Just curious.
Old Jun 26, 2005 | 11:55 PM
zrs's Avatar
zrs
Trying to use a 12v source that comes on when ignition is on. If anyone can provide a location I would appreciate it. Thanks for the help Ben91RS
Old Jun 27, 2005 | 12:08 PM
Ben91RS's Avatar
Usually (just depends on what your hooking up), the easiest place is the fuse box. There should be 2 slots on the right of the fuse box labeled "12V IGN" that you can use. That's what I use for my 12V ignition source. I know it's more wire to run, but it may be harder to find a 12V source in the engine compartment.
Might want to check the voltage on the the air pump solenoid connectors before you use one of them for your heated O2 sensor. I wouldn't be too surprised if those turn out to be 5 volt sources.
Old Jun 27, 2005 | 02:57 PM
zrs's Avatar
zrs
Fuse box it is then. Thanks for the help.
HectorM52
Jul 30, 2017 11:46 AM
linz
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
