Water pump = overheating
Old Jun 30, 2003 | 04:47 PM
Bristol's Avatar
Im trouble shooting an overheating problem and have a few questions. Im concerned that my water pump I have was packaged incorrectly ans is reverse flow. How can I check to see if this is the case???
Old Jun 30, 2003 | 05:43 PM
Damon's Avatar
Pop the back impeller plate off, see which way the impeller was designed to turn and see if your pulleys are spinning it that direction.
Old Jun 30, 2003 | 06:15 PM
Bristol's Avatar
Any way to check without removing from the car???
Old Jun 30, 2003 | 08:51 PM
TheGreatJ's Avatar
Crank the car, let it warm up a bit, and look down into the radiator. If you can see coolant circulating, it's the correct pump.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
pologreen97z
Dec 2, 2014 10:42 AM
