Trobleshooting A Squeeling Clutch Noise
Old Mar 31, 2004 | 06:58 PM
Ville H. Valo's Avatar
http://thirdgen.org/newdesign/tech/s...ngclutch.shtml
I am having them problem described in the artical, where is the shift fork/shift fork boot located?
Old Mar 31, 2004 | 10:48 PM
IROC-T's Avatar
That is the thing that kicks the clutch loose when you step on the peddel. It is located on the drivers side of the bellhousing about center, You can't miss it.
Old Mar 31, 2004 | 11:53 PM
what does it look like
Old Apr 1, 2004 | 01:45 PM
IROC-T's Avatar
Get under the car and have someone press the clutch peddle in , and out , and watch for movement. Like I said it is located on the drivers side of the bellhousing (looks like an arm with a rubber boot around it(could be leather). You CAN NOT miss it.
Ericksd
Jan 20, 2016 06:07 PM
autoxr166
Sep 25, 2015 04:21 PM
Ericksd
Sep 16, 2015 07:08 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
rideordie
Sep 7, 2015 08:22 AM
