timing issues?
Old Jun 15, 2002 | 12:50 AM
87beater's Avatar
Post timing issues?
is this the IAC? i put in a larger cam into my 305 and i cant seem to get the timing right... the funny thing is sometimes it will idle fine at 700 then sometimes it will bounce around at 5 to 800 and die.. but its always random... is this poss the Idle Air Control ... any help is much needed thanks.
Old Jun 15, 2002 | 01:38 AM
87beater's Avatar
Post
somebody please help...
Old Jun 15, 2002 | 10:47 AM
Bad 91z's Avatar
Post
100 rpms isnt much a difference. it might be fine.
Marty
91 Z28 4L60, electric red, 355. JE 11.1 flat tops, LT-1 rods, L-98 crank. Ported trick-flows by GTP, cc 306 grind, 1.6 chromemoly rr's, LT-1 intake fabricated for L-98. Tubular k-member,a-arms,manual rack-and-pinion,coil-overs,koni spa-1's. Ford 9" w/3.89's and spool. and still more to come.
'89 Mustang GT. just got it. only weight reduction mods so far.
'99 Neon R/T daily driver
Old Jun 15, 2002 | 10:51 AM
Bad 91z's Avatar
Post
It couldbe the IAC. or maybe you should make sure your getting enugh fuel.
Marty
Old Jun 15, 2002 | 08:33 PM
87beater's Avatar
Post
i just replaced the pump and relay and filter etc... the injectors are fine im getting enough gas the thing is sometimes it idles fine and sometimes it dies.. i dont get it.
97Z28Muscle
Feb 6, 2015 10:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Snoman73
Nov 17, 2014 07:22 PM
