Help! what is best way to mount TPIS AFPR?
Old Jun 15, 2002 | 09:00 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Exclamation Help! what is best way to mount TPIS AFPR?
well the intake comes off tomorrow, unfortunately have to buy T40 bit for the bolts, lost mine
i have a feeling it will run out over the valve cover after seeing where the schrader valve is?
tia!
taner
MY car featured:
http://www.bmrfabrication.com/Feature.htm
1996 Camaro SS A.R.E 398
11.36@120.35mph, NA
10.43@ 120.87mph N2O(i shifted 3rd to 6th,DOH!) 1.375 60'
Best mph: 132.95mph w/10.47- yes i hit 4th,lol (Sept 16/01)
oh yeah also an 80 Camaro, an 98 Ram Sport
"...i wish i was the full moon shining off a Camaro's hood..."
P.J.
Old Jun 15, 2002 | 09:25 PM
RedIrocZ-28's Avatar
Post
taner, I am unsure what "will run out." Do you mean gasoline will run onto the valve covers? If so just bleed the Schraeder valve with rag over the top of it to catch the initial spray. Another thing is that usually the fuel pressure drains off completely in the lines after a few hours.
If this is what you are talking about, you should be ok seeing as how the car has been sitting for a while already.
Old Jun 15, 2002 | 09:38 PM
taner's Avatar
Post
no fuel pressure, just when i MOUNT the gauge, do i fashion it so it is pointing out towards the pass. side valve cover. does that make better sense? ie. on my lt1 the gauge is at the back of the motor and barely visible.
no pressure in lines, i am ok there!
Old Jun 15, 2002 | 10:19 PM
ILLEGALZ28
Guest
Posts: n/a
Post
Position it so it aims at the passenger side. Take the valve stem out befroe you mount the gauge and put it in a specail place where it wont get lost. It is small and gets lost easy. trust me
1991 camaro Z28
350 TPI, T56, 4th gen rear with 3.73, chrome SS wheels, Ed Wright chip, comp cams RR, SLP dual cold air kit, LT1 injectors and cam, MSD ign, NX wet kit, ported TPI setup,and much more.
Old Jun 15, 2002 | 11:09 PM
taner's Avatar
Post
Illegal,
thanks, that is what i thought, i just wanted confirmation from someone who would has experience.
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
