stall converter
Old May 28, 2003 | 02:58 PM
  #16
Sitting Bull's Avatar
Most 305s poop-out at around 4500 rpm. With the LT1 cam you might hit 5000 rpm before it sags. Be sure to use new valve springs.
Old May 28, 2003 | 03:08 PM
  #17
STANGeatinZ's Avatar
thanks, also the lt1 cam isn't going to work b/c my car is not a roller cam motor. I did find a comp cam. that has 112/112 duration and .444/.444 lift so that's about the same.
Old May 30, 2003 | 12:53 AM
  #18
Nitromethane's Avatar
4200 stall... when you have the blown 350 u said its a drag car right. 2500 for the 305. I can't remember but I think converters like B&M/TCI are rated with 230 ft lbs of torque at 2000rpm or something like that, more torque means it'll stall higher, less torque and it'll stall lower - read B&M's site, it says it on there somewhere.
Old May 30, 2003 | 11:17 AM
  #19
thanks guys,
Derrick
thenewkid
Apr 12, 2015 07:42 PM
marine1bird
10
Jan 25, 2015 12:02 AM
Javier97Z28
Sep 8, 2002 07:23 AM
veryslowfbody
Aug 22, 2002 04:31 PM
TrouserSnake
Jul 22, 2002 05:34 PM
