Single electic fan or Dual electric fans ???
Old Oct 27, 2003 | 10:53 AM
shwine617's Avatar
I have dual electric fans in my car right now. I am taking my A/C out, So the will never be use for the second fan. I have a big single electric fan from another camaro and the top bracket looks the same. So it looks like it will go right in. Which type of fan setup would be better for better cooling, saving weight, and space.
thanks
Old Oct 27, 2003 | 12:39 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
dont take out the dual fans, they work alot better.
Old Oct 27, 2003 | 07:32 PM
shwine617's Avatar
yea, but only one of my fans work now cause i have no a/c.
and the single fan is bigger than one dual fan and it may be lighter. But can I tie the dual fans together so the both go on at the same time? instead of only when the a/c goes on? Because if I could do that then i'd rather have 2 fans
thanks!
Old Oct 27, 2003 | 08:24 PM
DarthIROC's Avatar
Most people wire the 2nd one to a switch.
Old Oct 27, 2003 | 08:27 PM
Ray86IROC's Avatar
You can easily rewire it to run, I have both of mine running as soon as the ignition is on, need to set up a switch for the winter...
Old Oct 28, 2003 | 12:08 AM
krazzycowgirl's Avatar
or hard wire it in to the battery that way it always is on when the key is on.
Old Oct 28, 2003 | 01:00 PM
Zepher's Avatar
I have both of my fans wired to 2 switches. Primary is on all the time and I turn the secondary on if I have the car idling for a long period of time.
DirtyDaveW
Mar 15, 2015 07:01 PM
Jan 23, 2015 01:13 PM
4586
Dec 31, 2014 02:21 PM
Jul 4, 2005 05:00 PM
