SES Code HELP!!
Old Nov 6, 2004 | 06:18 PM
350Z's Avatar
SES Code HELP!!
My manuals are still packed up and I got the SES light today.....can someone refresh my memory on the wire test using the ALDL connection so I can see what the problem is.
Thanks 350Z
Old Nov 6, 2004 | 06:38 PM
350Z's Avatar
Re: SES Code HELP!!
OK I ran the codes and it flashed the code 12 three times then it flashed three times quickly then paused then six times quickly then paused......repeated this a few times....there are no code 3's or 6's....WTF is it?? The car is an 89 Iroc w/350..thanks!!
350Z
Old Nov 6, 2004 | 06:52 PM
Kwiksilverz28's Avatar
Re: SES Code HELP!!
It's code 36, which is MAF burn off. Replace the relay first, then consider the MAF....
Old Nov 6, 2004 | 08:18 PM
350Z's Avatar
Re: SES Code HELP!!
Cool!! Thanks for the help man....
Old Nov 7, 2004 | 09:17 AM
Scrote's Avatar
Re: SES Code HELP!!
Hey Trevor...
I would replace the relay, but dont go any further than that as a new sensor from Bosch is like 400.00 and even a reman is like 200.00 something. Just dont fire the ole parts shotgun at the IROC. I have some Non scan diagnostic tree's i can fax you if you would like. I have the same problem in the Z but it is the ECM.
You just dont want to make a 4 hundo dollar mistake in your diagnosis...
Later bro,
Erik
Old Nov 7, 2004 | 01:08 PM
Re: SES Code HELP!!
$163 from Autozone. I agree. Swap the relay and then clear the codes. If it pops up again, try to find another sensor to try....like borrow from a friend or something....
Old Nov 7, 2004 | 04:28 PM
350Z's Avatar
Re: SES Code HELP!!
Thanks ******.....the relay went in and I cleared the codes....doing good right now.....
350Z
Old Nov 8, 2004 | 03:35 PM
Scrote's Avatar
Re: SES Code HELP!!
No problem Trev...Hey i got your call...but it was real late and I know you military types like to get to bed early ....sooooo I will try to give you a call tonight after I get back from the Gym...
Later,
Erik
Old Nov 9, 2004 | 10:39 AM
LT1Powered85Z's Avatar
Re: SES Code HELP!!
I called you back an hour after you called me and I left a message. So...check your voicemail, if you haven't already, and give me a call back. I'll be available tonight after work.
Glad to see you post.
Eric
BigED
Jun 23, 2015 07:19 PM
Hannibal
Sep 10, 2002 04:25 PM
Hannibal
Sep 6, 2002 05:07 AM
lax037
Aug 18, 2002 02:07 PM
91Bird305
Aug 5, 2002 01:39 PM
