SD Systems still have a MAF right?
Old Jan 10, 2004 | 04:37 PM
  #16
Black6SpdTA's Avatar
Originally posted by Zepher
Just convert to SD.
Costs about $100 or so.
Just need an extra ECM connector, Knock Sensor, ECM and Prom, and a MAP sensor (can't remember if there is a MAP sensor on the MAF cars or not).
I had Jonh Millican re-pin my harness for me since I wasn't too familiar with pulling the wires out of the ecm connectors.
Sweet, that's cheap! Would it even be worth it though? What's MAF's downfall? Going to be a Superram 383.
Old Jan 10, 2004 | 07:03 PM
  #17
aklim's Avatar
MAF has been said to be a restrictive flow problem. Some people have ported their MAF units but if you do so, the calibration might be off. In that case, you better be able to recalibrate the EPROM to make it work.
That said, there is no doubt in my mind that MAF responds to engine changes better than SD
Old Jan 10, 2004 | 08:24 PM
  #18
Zepher's Avatar
With Speed Density, you can program for maximum power. With MAF, you have the limitation of the MAF sensor.
If you plan on tuning your car yourself, go SD, if not, then MAF responds better to mods without programming.
Old Jan 10, 2004 | 10:33 PM
  #19
Ok, I think I'm going to stay MAF. I won't be doing my own tuning for ~2-3yrs and until then I'll just have someone burn me a chip. The kind that they burn it, then they burn it like 3 times to get it dead on. Or do I need a laptop to log the data for them? Oh well I'll just have it dyno tuned haha I wish.
From what you said Manny, it seems like it's not difficult to swap so I can even do it while the motor is in the car pretty simply.
-Corey
Old Jan 11, 2004 | 10:55 AM
  #20
Zepher's Avatar
Ya, to get the best tune, you'll need to data log the car and send the info to the tuner.
Swapping to SD is done with the motor in the car, there is no need to pull it out.
You'll probably want to pull the harness out of the car though so you are not lying on the pass side floorboard trying to re-pin the ecm connectors.
Old Jan 11, 2004 | 11:09 AM
  #21
aklim's Avatar
Fasterproms.com can burn it for you. Borrow their Diacom software and cable. Install program to laptop. Make the runs as specified and email files to them. They send you another chip. Do the same. Bu this time it should be on the money. Send data to them. If they tell you it is right on, send equipment and other chips back and that is that.
Old Jan 11, 2004 | 11:14 AM
  #22
Zepher's Avatar
I am not sure how far you are from these guys,
http://www.carolinaautomasters.com/
but they may be able to tune your 3rd gen.
DirtyDaveW
Dec 1, 2016 05:37 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Chicago94Z28
Aug 28, 2002 08:31 PM
