Question on oil-smoking
Old Mar 22, 2003 | 12:02 PM
85_LG4
Guest
Posts: n/a
Question Question on oil-smoking
Is it tru that using thick oil (dont remember exact weight, but it is written on paper at home!) and putting in a certain amount of gear-lube or rear-end lube (again, dont remember how much, but i have it written down at home) will stop the blue-smoke in my '85 Z-28? What if i were to combine this oil with some RESTORE... do ya guys/gals think it will work? car has 197,000 miles on it, and STILL pullin strong!
Old Mar 22, 2003 | 02:56 PM
85_LG4
Guest
Posts: n/a
Umm... ok, no help here either?
Old Mar 22, 2003 | 03:13 PM
AndrewC's Avatar
uh no
but you might wanna do your valve seals, to fix the problem. with an air compressor and valve spring compressor you can do them with just the valve covers off.
Old Mar 22, 2003 | 03:45 PM
85_LG4
Guest
Posts: n/a
that wont help? And If anything... wont i have to redue the Piston Rings?
Old Mar 23, 2003 | 05:47 AM
87DJP2001's Avatar
Additives will not help wore valve seals and stop the white smoke on start ups. Just a common problem on SBC engines with high milage. Replace as stated or live with it, will not result in any damageor loss of performance.
Old Mar 23, 2003 | 11:42 AM
85_LG4
Guest
Posts: n/a
Actualy its blue smoke, and realy is only there after the car warms up... so isnt it oil goingh thru the Rings? what makes ya think that its the Valve Seals?
Old Mar 23, 2003 | 12:02 PM
87DJP2001's Avatar
Ok. Wrong conculsion...
Old Mar 23, 2003 | 12:42 PM
85_LG4
Guest
Posts: n/a
What is that suppoed ta mean?
Old Mar 23, 2003 | 09:15 PM
TheGreatJ's Avatar
Oil smoke on startup is a common problem with SBC's, and is almost always caused by worn valve seals. Oil smoke after the engine is warm is usually blowbye, which is caused by worn rings and can only really be fixed by a rebuild. Running 20/50 oil will reduce the smoke, and running 80/90 mixed in will almost certainly stop it, but that's an awfully thick oil for your oil pump to be pushing through the engine. It will probably be alright for a while but the strain is gonna kill your oil pump eventually.
Also replace your PCV valve.....if it's bad that can cause it to burn a little oil.
Old Mar 25, 2003 | 08:06 PM
85_LG4
Guest
Posts: n/a
Alright... thanx for tha info! So i guess ill check the PCV first... thanx!
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
