need help with trans
Old Mar 23, 2003 | 05:58 PM
LETSROC1's Avatar
Lightbulb need help with trans
I need a lot of HELP I have a 85 IROC-Z.The trans is holding in gear at 4500 rpm's and will not shift until I let off the gas.I can take it up to 5200 rpm's and it still pulls strong.The trans is a 700r4.Can any one help me???????????????????????
Old Mar 24, 2003 | 09:12 PM
kjlvilla's Avatar
Is this all gears? Your T.V. and governor fight eachother for shift times, try adjusting your T.V. cable. Also a driveability problem will prevent a WOT upshift because your output shaft speed (governor speed, i.e pressure) will not be fast enough to overcome T.V. pressure. Your engine will rev. but your car will not be going the correct speed because of the lack of power. Try changing your fuel filter if it's got a lot of miles.
Old Mar 24, 2003 | 09:26 PM
LETSROC1's Avatar
It does it from a dead stop when it hits 4500 rpm it want shift.And I can be running down the road and nail it and again when it hits 4500 rpm it stills hold until I let off the gas.I put a new fuel filter on to.So could it be the motor.Thanks for your help.
take a look at my web page http://members.sounddomain.com/letsroc1
Old Mar 25, 2003 | 08:11 PM
kjlvilla's Avatar
It still sounds like your engine isn't making enough power under WOT. Did this just start happening? Did you do anything to the engine just before this started happening? Even filling it with gas? Maybe a tank of bad gas. My car shifts after 4500 rpms so it sounds like your engine won't rev high enough. Try pulling your air filters and retesting. Do you have access to a scanner? If so, what is your tps, and O2 vt? If they are running low it will pull fuel at WOT. Good luck.
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 23, 2015 12:59 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
