question?
Old Apr 17, 2009 | 10:08 PM
chevynutman's Avatar
question?
im getting a 350 with he said an 'rv' cam
if i had the heads shaved would it boost compression and horsepower
and if so
how much should i get shaved
and also
should i get slp studs or would regular head bolts be fine
Old Apr 18, 2009 | 12:56 AM
quickchicken's Avatar
what are your plans for this motor? 40% race, 60% street or what? thats the first ques. and are you running a TPI intake, carb or TBI? an RV cam is designed with lots of torque to move it. once you figure out what your going to do with hte motor start planning your cam.
Old Apr 18, 2009 | 08:52 PM
im doing 98% street with some weekend racing but this is a daily driver
i do have tpi
im just lookin to add a little more hp with a little less cash and since it already has the cam in it thats one thing i dont need
Old Apr 19, 2009 | 07:40 AM
cnorton's Avatar
Regular head bolts will serve just fine for 99.9% of daily-driver applications. If you decide to upgrade, consider an ARP bolt kit. Search this forum for information regarding an appropriate head bolt sealer. You'll get more information than you can ever use.
Good luck,
c
Old Apr 19, 2009 | 07:59 PM
a mild cam will do ALOT for a TPI. a comp 08-300-8 is what we put in my friends 88 GTA L98 car and its quite obnoxious. we put hooker 2055's, magnaflow hi flow cat and edelbrock cat back system. other than that and the cam its all stock.
Old Apr 20, 2009 | 08:46 PM
thanks guys-
i think i will just port and polish the heads to start and see how it goes
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
