Proportioning Valve: Drums to Discs
Old 10-23-2003, 07:26 PM
Black6SpdTA's Avatar
My LT1 rear brakes came today. Will I need a 4-wheel disc proportioning valve? If so, can I get one off of a 4th gen? Thanks
-Rippin
Black6SpdTA is offline
Old 10-23-2003, 11:29 PM
Dave89IROC's Avatar
IIRC, in 89-92, all F-bodys used the same Prop valve, disc/drum and disc/disc
so the one you have should work fine
Dave89IROC is offline
Old 10-24-2003, 03:20 PM
Dave,
I hope you're right but I remember reading that Drum/Disc were set up 70/30 compared to Disc/Disc being 60/40.
-Rippin
Old 10-25-2003, 12:01 AM
slow_roc's Avatar
if you need a disc prop valve i have one off a older 3rd gen trans am 10 plus shipping if ya want it
thanx steve
slow_roc is offline
Old 10-25-2003, 01:47 PM
If I end up needing one, you'll be the guy I'll talk to Hopefully I can use mine though. Thanks. Hasn't anyone on here gone from drums to discs?
-Rippin
Old 10-25-2003, 02:29 PM
TheGreatJ's Avatar
I went from drums to discs, and since I wasn't sure about the valve I went ahead and got a J65 (4-wheel disc) valve from the dealer. I wanted a spare one to gut and add an adjustable bias valve to anyway.
I hear the drum valve works fine, but I also hear it causes problems with hard stops (i.e. the front brakes lock up but the back wheels keep pushing the car and you end up going around in circles very very quickly.) I'd say try it and then change it later if you have to.
If you decide to change it, keep this in mind. GM changed the brake lines from standard thread to metric thread in either '90 or '91, so you'll need a metric-thread valve if you want your lines to fit.
TheGreatJ is offline
Old 10-26-2003, 03:21 PM
jayman350's Avatar
yeah I sawpped from drum to disc at the end of the summer, I bought a prop valve off of ebay for a few bucks cause I didn't want to chance having the brakes lock up on me
its a very easy swap to do, are you putting just new brakes on or a whole new rear?
jayman350 is offline
Old 10-26-2003, 03:36 PM
Whole new rear. Brakes are included but I don't think the prop valve is. I know it's a cheap piece but money's money.
-Rippin
Old 10-26-2003, 04:54 PM
3rd Gen Tech Moderator
Kevin91Z's Avatar
My dad swapped his 92 RS from drums to discs and used the same prop valve and master cylinder with no problems. GM used the same ones from 89-92 regardless of drums or discs. If you decide to change yours, you need one from 89-92. Do not use one from 82-88.
Kevin91Z is offline
Old 10-27-2003, 10:42 AM
Marc 85Z28's Avatar
Just to add some confusion... I swapped to LT1 rear disc brakes when I added the new rear. I DID NOT change the master cylinder or the prop valve. I figured I'd run it for a little while to see how it performs and change over if necessary. In my experience it's a waste of time and money. My rear brakes do not lock up, and the front only lock up in occassional panic situations - they did that before. The car stops noticably better than with the rear drums and I can stall the converter an extra 200 RPM with the rear discs, so they are doing their job.
Marc 85Z28 is offline
sleeperZ96BT
09-09-2015 08:28 AM
karpetcm
08-14-2015 03:02 PM
Team Untouchable
V6 Tech
09-06-2002 05:19 PM
RadarRunner
08-18-2002 01:11 PM
stars1010
West South Central
07-09-2002 03:55 PM
Quick Reply: Proportioning Valve: Drums to Discs
