posi
Old Mar 7, 2003 | 06:20 PM
cowlcamaro's Avatar
Question posi
Can you weld a limited slip rearend if so how hard would it be.
Old Mar 7, 2003 | 10:01 PM
Aaron91RS's Avatar
You can always weld the spider gears but if it's posi why?
If you do you'll break it soon after if you use it for a daily driver and make turns.
Old Mar 7, 2003 | 10:03 PM
aklim's Avatar
If you are going that route, why not just get a spool? You couldn't turn corners well but if that is what you want, go for it.
Old Mar 7, 2003 | 10:15 PM
brodyscamaro's Avatar
i would do a mini spool then. you will still be able to turn with it though.
Old Mar 7, 2003 | 11:15 PM
stevem's Avatar
i have a buddy who had a jeep cj7 with the spiders welded he drove it for three years then sold it and as far as i know they have not broke yet.by the way he was running 44 inch boggers and it was a daily driver.
Old Mar 8, 2003 | 08:52 PM
TheGreatJ's Avatar
Tires that big have a very tall sidewall which will deflect a lot and take up the stress of the welded spider gears. Unless you're putting 44's on your Camaro, it won't hold up nearly as long. I've seen them last a month or 2, but no more.
Old Mar 8, 2003 | 09:56 PM
stevem's Avatar
if its donr right it will hold
yhe 44 inch boggers were 16 inches wide
oh and he mud raced it all the time
but if can afford a posi or spool get that instead
vwb11356
Jul 22, 2015 06:51 PM
mrwz28
Jul 8, 2015 09:11 PM
cristian1311
May 1, 2015 08:56 PM
TitoPR221
Jan 29, 2015 08:00 PM
