oily plugs...
Old Jun 5, 2004 | 01:31 PM
ed's85irocz28's Avatar
oily plugs...
Most of the plugs were complely black and oily. I think they were the same plugs that were always in the car. They were all gapped over 40. I replaced them all with AC delco plugs that were gapped to 35
What does that tell if the plugs are oily?
Old Jun 5, 2004 | 01:59 PM
IROC-T's Avatar
Re: oily plugs...
[i]
What does that tell if the plugs are oily? [/B]
Your burnning oil!
Could be rings,or it could be valve seals/guides. You need to run a compression test.
Old Jun 5, 2004 | 02:40 PM
Pneumatic_Tire's Avatar
Your plugs are suppose to be gapped at .045. (Unless you have a TPI, I'm not sure about those.)
Also, PLUGS MAY SAY THEY ARE PRE GAPPED, BUT THEY AINT. Just check them and see.
If your plugs have oil on them, assuming you arn't mistaking carbon buildup for oil, then most likely you have problems with your piston rings. Scored cylinder walls, or badly worn rings are allowing oil to get passed the rings and into the combustion chamber.
EDIT: Just read your sig, and you have a TPI. Make sure the plug gap is suppose to be .035. It should say under your hood somewhere on a sticker.
Old Jun 5, 2004 | 05:58 PM
aklim's Avatar
Run a leakdown test and see where it is leaking at and how much. It could be rings sealing or the valve seals.
Old Jun 5, 2004 | 11:00 PM
the plugs that were it in were gapped to about 40, the new ones were all about 35. I'll probably try to get some new rings.
Old Jun 6, 2004 | 12:41 AM
aklim's Avatar
35 or 40 won't make that much of a difference as to making oil appear on the plugs.
If you are going with new rings, you might as well hone the block and change the bearings while you are at it.
Old Jun 6, 2004 | 12:48 AM
how much do you think it would cost for all that total?
i'm new to all this and dont know any prices
Old Jun 6, 2004 | 12:56 AM
aklim's Avatar
You'd have to take it to a machine shop. They might tell you that you could get away with honing the bores or they might tell you to refresh the entire engine with new oversized pistons. Hard to say at this point.
Grimm71
Jun 24, 2015 02:17 PM
alex5366
Feb 17, 2015 10:43 PM
RichJ
Jun 3, 2005 08:49 PM
98Z-6speed
Dec 22, 2003 07:53 PM
