Oil on valve cover/under car
Old Jun 5, 2004 | 01:13 PM
dj haf's Avatar
i noticed that a little bit of oil was ontop of my valve cover, and it seems to be comming from the oil cap... so my first thought was that if i replace the oil cap, the problem will go away. while inspecting the bottom of the car i noticed a drip of oil on the oil filter, and the tubes to the oil cooler were covered with oil. what could be causing this problem? i noticed it right after i got my engine back from having it rebuilt, but if it's nothing major, im not going to bother taking it somewhere, i'd rather fix it myself. thanks guys
Old Jun 5, 2004 | 02:07 PM
IROC-T's Avatar
Not actually seeing the car and what you describe I would say worst case senierio too much crankcase pressure (bad ring job,bad PCV,etc.),or loose bolts where it seals(valve covers,oil pan etc.),or excessive oil pressure.
Old Jun 5, 2004 | 07:27 PM
Pneumatic_Tire's Avatar
Maybe someone missed when putting oil in it.
Old Jun 6, 2004 | 05:02 AM
aklim's Avatar
Run a compression test and see what you have. Best thing of course is to run a leakdown test and see where it is going to but a compression test will be a start.
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
