Name That Problem
Old Oct 27, 2003 | 10:09 AM
  #16
IROC5.7TPI's Avatar
Most likely cause- Coolant Temp sensor. It will read false readings back to the ecm and the ecm will try and compensate. It olny costs $10 and is relatively easy to replace. I would start there.
Old Oct 27, 2003 | 12:51 PM
  #17
Kuruption562's Avatar
Originally posted by shwine617
no I mean your dipstick, do you have to add oil once in a while? because your probably burinig it.
Nope, It stays the same.
Old Oct 27, 2003 | 01:02 PM
  #18
Aiiight Ill Look into that, where is that sensor located?
Old Oct 27, 2003 | 01:43 PM
  #19
aklim's Avatar
Right in the front of the manifold. 2 wires going into a sensor which screws into the manifold
Old Oct 27, 2003 | 03:53 PM
  #20
RedIrocZ-28's Avatar
Its either your Coolant temp sensor OR your O2 sensor. Aks me how I know I know you said you replaced your O2 sensor, but go get a Bosch with the plug already on it. That will clear up your problem. Night and Day my man... night and day.
Old Oct 27, 2003 | 08:39 PM
  #21
How Do you know its my o2 sensor or my coolant temp?
Im On my way to buy my coolant sensor in about 20 mins, hopefully it helps.
Should i really buy a different o2 sensor? is it worth buying a new one i just put mines in last week.
Old Oct 28, 2003 | 12:40 AM
  #22
aklim's Avatar
Hold off the O2 sensor until you have determined the problem to not be the temp sensor
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
